| What do you guys think, new prop??? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=2593 |
| Author: | DUCKSBANE [ Tue Jun 16, 2009 9:10 am ] |
| Post subject: | What do you guys think, new prop??? |
Ran the boat. It sounds alot more impressive than it runs, Real deep strong sounding motor. Runs alot better than it did when it was stock. The motor did about what silkpower told me it would do with the mods I have. Mods are decked heads, EVT muffler, valve shimmed, port and polished and carb has bigger jets. With 2 guys 230 and 210 blind and grass(150 to 200) and dog 65 we ran 25.5 mph in the shallows(1ft), 23.7 mph in the deep. There is alot of hesitation on the bottom end when going from rest to putting the hammer down. Once it kicks in it jumps out of the hole pretty quick. Load will be the real test as thats what Im looking for. Thinking I may need a new prop with a different pitch. Boat ran best at 3850 which is the same that it did before the mods. Any higher rpm than 3900 and my speed dropped. Prop I have on it is stock and atleast 85%. What do you guys think??? Rod you got a link to one of those oil coolers? |
| Author: | coondik [ Tue Jun 16, 2009 10:32 am ] |
| Post subject: | Re: What do you guys think, new prop??? |
NAPA p/n 14818 |
| Author: | drake1 [ Tue Jun 16, 2009 11:30 am ] |
Need a differnet carb and intake. You still may not be getting enough fuel to the stock carb. Adjust the air mixture screws on each side of the carb and make sure you are getting wide open throttle from the gov. |
| Author: | coondik [ Thu Jun 18, 2009 1:09 pm ] |
dis 1 DB8 |
| Author: | deadbird8 [ Thu Jun 18, 2009 3:50 pm ] |
| Author: | Brinkleydog [ Thu Jun 18, 2009 6:16 pm ] |
How much u guy paying for the oil coolers. I can get you one built that wil perform better than that for about 30 bucks. Later |
| Author: | coondik [ Thu Jun 18, 2009 7:40 pm ] |
B-Dog: the napa ones go for a/b 35 bucks! Cheaper & better! Get me one ASAP |
| Author: | Brinkleydog [ Thu Jun 18, 2009 8:07 pm ] |
Ill send it back with Aucoin.....what size lines u use for inlet and outlet? |
| Author: | coondik [ Thu Jun 18, 2009 8:21 pm ] |
3/8" Be sure to show it to Mike & Robert(EVT) It would be real sweet if u could make one that would fit in place of the front grill thingy & use de some bolt holes |
| Author: | Brinkleydog [ Thu Jun 18, 2009 8:49 pm ] |
I can make it bolt up just need the dem. from hole to hole. When i get my moto back i can pre punch the bolt holes but u gona have to drill..... sorry dikdik |
