27 kohler
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=25947
Author:  DuckHunter251 [ Fri Jan 20, 2012 12:20 pm ]
Post subject:  27 kohler
Does anyone know what the valve lash is for the 27? Thanks in advance Matt
Author:  50fps [ Fri Jan 20, 2012 1:02 pm ]
Post subject:  Re: 27 kohler
No lash adjustment, it has hyd lifters and the pedestal bolt is torqued to spec (100 in lb) with the lifters bled down.
This may help you.
http://www.kohlerengines.com/onlinecata ... 690_06.pdf
Author:  DuckHunter251 [ Fri Jan 20, 2012 3:02 pm ]
Thanks man didn't know that. The issue I'm having is a high pitched rattling from Time to time at full throttle. The sound seems to be coming from the head area of the motor. If I let off the throttle alittle for 45 or so seconds It will stop and I can go back to wot again. I check the bps muffler and that's not it.
