It is currently Sun Jul 13, 2025 3:56 am
Reply to topic  [ 16 posts ]
 Gas in oil
Post Gas in oil
I have gas in my oil on my 27 Kohler, I already checked my fuel pump so it must be my float stuck? Right? Any tips?
Sent from my Evo 4G 3D
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Thu Jan 26, 2012 6:16 pm
Post Re: Gas in oil
Is it burning any oil?
If the float is stuck it will run like shit, has it been doing that?
Thu Jan 26, 2012 6:19 pm
Post Re: Gas in oil
Yeah lately it has
Thu Jan 26, 2012 6:21 pm
Post Re: Gas in oil
I'd definitely check that, is it flooding any?
Thu Jan 26, 2012 6:45 pm
Post Re: Gas in oil
Yeah I just checked the float
Thu Jan 26, 2012 6:55 pm
Post Re: Gas in oil
I just checked the float , I cleaned it up made it move freely, no trash in the carb, , tomorrow after work imma go pick up a few more oil filters and more oil and try it again, hopefully I get it running for the lil mud run we having,
Thu Jan 26, 2012 7:13 pm
Post Re: Gas in oil
It may not have trash in it and still stick.
Sometimes all it takes is completely taking it apart and spraying carb cleaner on all the parts then re-assembling it.
I've fooled with several stuck floats that had no visible trash in it, took it apart, put it back together and worked fine.
Good luck.
Thu Jan 26, 2012 7:23 pm
Post Re: Re: Gas in oil
Thu Jan 26, 2012 7:26 pm
Post Re: Gas in oil
Should I take the whole carb apart?
Fri Jan 27, 2012 9:35 am
Post Re: Gas in oil
Take a pick and a little piece of steel wool and clean the seat
Fri Jan 27, 2012 10:05 am
Fri Jan 27, 2012 11:39 am
Post Re: Gas in oil
I never messed with carbs other than my 16 vanguard, that one was simple, my Kohler has wires and shit everywhere
Fri Jan 27, 2012 12:04 pm
Post Re: Gas in oil
The spot where the needle valve sits. Sometime it will get a little debris k nit and not seat properly
Fri Jan 27, 2012 12:28 pm
Post Re: Gas in oil
or the rubber on the tip of the needle in some cases cracks and will leak :?:
Fri Jan 27, 2012 2:08 pm
Post Re: Gas in oil
Okay that's what I thought it was, , does anyone have pictures of a tear down on a Kohler carb?
Fri Jan 27, 2012 2:19 pm
Post Re: Gas in oil
I found the problem, the o-ring on the lil brass tube broke and was making my float stay open, but I don't have a o-ring on hand, kinda bummed
Fri Jan 27, 2012 6:04 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 66 guests
