Gas in oil
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=26119
Author:  Bayoublackhunter [ Thu Jan 26, 2012 6:16 pm ]
Post subject:  Gas in oil
I have gas in my oil on my 27 Kohler, I already checked my fuel pump so it must be my float stuck? Right? Any tips?
Sent from my Evo 4G 3D
Author:  Woodiebuster [ Thu Jan 26, 2012 6:19 pm ]
Post subject:  Re: Gas in oil
Is it burning any oil?
If the float is stuck it will run like shit, has it been doing that?
Author:  Bayoublackhunter [ Thu Jan 26, 2012 6:21 pm ]
Yeah lately it has
Author:  Woodiebuster [ Thu Jan 26, 2012 6:45 pm ]
I'd definitely check that, is it flooding any?
Author:  Bayoublackhunter [ Thu Jan 26, 2012 6:55 pm ]
Yeah I just checked the float
Author:  Bayoublackhunter [ Thu Jan 26, 2012 7:13 pm ]
I just checked the float , I cleaned it up made it move freely, no trash in the carb, , tomorrow after work imma go pick up a few more oil filters and more oil and try it again, hopefully I get it running for the lil mud run we having,
Author:  Woodiebuster [ Thu Jan 26, 2012 7:23 pm ]
It may not have trash in it and still stick.
Sometimes all it takes is completely taking it apart and spraying carb cleaner on all the parts then re-assembling it.
I've fooled with several stuck floats that had no visible trash in it, took it apart, put it back together and worked fine.
Good luck.
Author:  Bayoublackhunter [ Thu Jan 26, 2012 7:26 pm ]
Post subject:  Re: Re: Gas in oil
Author:  Bayoublackhunter [ Fri Jan 27, 2012 9:35 am ]
Should I take the whole carb apart?
Author:  garrettpearce [ Fri Jan 27, 2012 10:05 am ]
Take a pick and a little piece of steel wool and clean the seat
Author:  Bayoublackhunter [ Fri Jan 27, 2012 11:39 am ]
Author:  Bayoublackhunter [ Fri Jan 27, 2012 12:04 pm ]
I never messed with carbs other than my 16 vanguard, that one was simple, my Kohler has wires and shit everywhere
Author:  garrettpearce [ Fri Jan 27, 2012 12:28 pm ]
The spot where the needle valve sits. Sometime it will get a little debris k nit and not seat properly
Author:  wm [ Fri Jan 27, 2012 2:08 pm ]
or the rubber on the tip of the needle in some cases cracks and will leak :?:
Author:  Bayoublackhunter [ Fri Jan 27, 2012 2:19 pm ]
Okay that's what I thought it was, , does anyone have pictures of a tear down on a Kohler carb?
Author:  Bayoublackhunter [ Fri Jan 27, 2012 6:04 pm ]
I found the problem, the o-ring on the lil brass tube broke and was making my float stay open, but I don't have a o-ring on hand, kinda bummed
