CAMO PAINT JOB http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=26192 |
Page 1 of 2 |
Author: | catfish16020 [ Sun Jan 29, 2012 5:15 pm ] |
Post subject: | CAMO PAINT JOB |
Looking for camo paint job ideas Any one try any stencle kitts that you find on line? |
Author: | Bayoublackhunter [ Sun Jan 29, 2012 5:41 pm ] |
Post subject: | Re: CAMO PAINT JOB |
I got mine off Ebay, I had mine made Sent from my Evo 4G 3D |
Author: | deadbird8 [ Sun Jan 29, 2012 6:30 pm ] |
Styx River MOSG |
Author: | greg f [ Sun Jan 29, 2012 7:04 pm ] |
Author: | scatters boy 316 [ Sun Jan 29, 2012 7:29 pm ] |
Author: | med [ Sun Jan 29, 2012 7:35 pm ] |
Styxriver natgear |
Author: | greg f [ Sun Jan 29, 2012 8:42 pm ] |
My advice is if you buy the styx river stencils, buy 2 sets. They get loaded up w/ paint and they're not easy to clean as you go along. I painted my hull w/ the shadow grass and mine came out good but the 1 above came out much cleaner. |
Author: | greg f [ Sun Jan 29, 2012 8:43 pm ] |
Oh, nice job med......looks good. |
Author: | deadbird8 [ Sun Jan 29, 2012 9:14 pm ] |
Author: | SammyC [ Sun Jan 29, 2012 10:25 pm ] |
I also can't say enough good about styxx stencils. Thanks med... |
Author: | Fall Flight [ Wed Feb 08, 2012 10:48 am ] |
MOSG from Styx River. Wish I could paint as good as DB |
Author: | Z71v2.0 [ Wed Feb 08, 2012 5:12 pm ] |
Did this with a rattle can. |
Author: | DirtNasty [ Wed Feb 08, 2012 8:37 pm ] |
How are yall prepping the aluminium? Ive hread something about using an etching primer??? |
Author: | take'emgator [ Wed Feb 08, 2012 8:41 pm ] |
Sent mine off and had it done, easiest paint job i've ever done and come out top notch |
Author: | duckduckboom [ Wed Feb 08, 2012 9:28 pm ] |
Author: | DirtNasty [ Thu Feb 09, 2012 8:02 am ] |
Author: | dfou [ Thu Feb 09, 2012 8:30 am ] |
Don't sandblast. Just scuff it up with sandpaper and make sure you get all the loose paint off then clean it good and apply new paint |
Author: | CJB [ Thu Feb 09, 2012 9:23 am ] |
Author: | lastchance [ Thu Feb 09, 2012 10:01 am ] |
X3 Sand blasting also makes the bottom of the boat rough and causes loss of speed! |
Author: | centxhunter [ Thu Feb 09, 2012 10:53 am ] |
These paint jobs look fantastic. Question: On the camo paint on the engines, doesn't that sh*t get hot and burn or somoke? I know you don't do the pipes, but even some of the other parts.. sure look great though. Not sure how you get the stencil pattern so well defined in all the nooks and crannies? Outdrive is easy(er). |
Author: | mcduffws [ Thu Feb 09, 2012 12:17 pm ] |
Styxx River is the way to go |
Author: | WestEndAngler [ Thu Feb 09, 2012 1:57 pm ] |
I'm sending mine off in a few months to get repainted. Going to go with a clear coat like many others have done. |
Author: | DirtNasty [ Thu Feb 09, 2012 2:25 pm ] |
Clear coat?? Please explain.. |
Author: | take'emgator [ Thu Feb 09, 2012 2:29 pm ] |
Some camo places throw a protective coating on there that sort of looks like clear coat i have it on my boat, very easy to wash mudd off and it looks real nice, not a whole lot of glare when hunting. |
Author: | cb5331 [ Thu Feb 09, 2012 2:30 pm ] |
Post subject: | Re: Re: CAMO PAINT JOB |
Author: | take'emgator [ Thu Feb 09, 2012 2:31 pm ] |
Oh and i forgot, it doesn't fade, if it does i bring it back and they will repaiint it I got some pics hang on |
Author: | WestEndAngler [ Thu Feb 09, 2012 2:47 pm ] |
Author: | OwenDickeson [ Thu Feb 09, 2012 2:52 pm ] |
Camo Designs uses a satin clear on most boats. |
Author: | WestEndAngler [ Thu Feb 09, 2012 2:54 pm ] |
Author: | OwenDickeson [ Thu Feb 09, 2012 2:57 pm ] |
It's all in the technique of how you spray it that determines how glossy or flat it comes out in the end. |
Author: | brasso [ Thu Feb 09, 2012 3:55 pm ] |
Author: | whytry85 [ Thu Feb 09, 2012 6:35 pm ] |
Real foot stencil |
Author: | djjm67 [ Mon Feb 20, 2012 6:32 am ] |
I was also wondering about the paint on the engine itself. Was wanting to paint my prodrive but wasnt sure if I needed to use some sort of heat paint. Haven't really seen any of the the colors that u would want for camp in a heat paint. |
Author: | med [ Mon Feb 20, 2012 6:48 am ] |
Author: | DeathMetalDukk [ Mon Feb 20, 2012 6:58 am ] |
Author: | OwenDickeson [ Mon Feb 20, 2012 7:41 am ] |
Author: | med [ Mon Feb 20, 2012 8:04 am ] |
Yeah I know. I just figured if you had a flat clear that it would be flat when applied regardless of technique. |
Author: | greg f [ Tue Feb 21, 2012 5:55 pm ] |
When you spray the flat clears if you don't get a completely even coat it can look a little glossier in certain areas. |
Author: | Z71v2.0 [ Thu Feb 23, 2012 11:44 pm ] |
Author: | brasso [ Thu Feb 23, 2012 11:53 pm ] |
You have any more pics of It? |
Page 1 of 2 | All times are UTC - 6 hours |
