It is currently Fri Jul 11, 2025 7:09 pm
Reply to topic  [ 5 posts ]
 Case gasket......
Post Case gasket......
Ok boys, going to have to change my case gasket out when it gets warmer! I've got the gasket kit and even new tower bushings! Any tips, advise or suggestions on special tools I'll need???
"Gofer Everette?"
Sun Feb 05, 2012 7:13 am
Profile YIM WWW
Post Re: Case gasket......
Sun Feb 05, 2012 8:05 am
Get the flatout gasket and just clean everything really good,Loctite bolts and torque to specs and done ;)That worked for me!
Sun Feb 05, 2012 8:27 am
If the clutch is being stubborn coming off, a 3 prong puller will really speed up the process.
Emory cloth to clean the gasket surface & will also give you a good surface profile for your gasket sealer to grab to.
And its always good to have a bag of microfiber rags for cleaning up.
Be careful when putting the case back together and dont pinch the rear PTO seal around the shaft. I learned that the hard way.
Oh and you might as well slide a new cam in there while its open! ;)
Sun Feb 05, 2012 10:26 am
Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Mon Feb 06, 2012 3:50 pm
Users browsing this forum: No registered users and 141 guests
