It is currently Wed Jul 16, 2025 9:48 am
Reply to topic  [ 14 posts ]
 Idle problems
Post Idle problems
So I have a 36pd 08 model so when I go to engage the clutch it will not idle out, I have to milk the throttle for it to not die looking for any solutions to fix this
1748 SDB being pushed by a 36pd
Mon Feb 06, 2012 1:57 pm
Post Re: Idle problems
What rpm is it idling at?
It should be 1100-1200.
Mon Feb 06, 2012 1:58 pm
No it's not it's around 900 or so
Mon Feb 06, 2012 2:02 pm
Mon Feb 06, 2012 4:18 pm
Post Idle problems
Instead If adjusting your idle with the carb setting adjust by bending arm on governor spring!!
17x48 extreme stage 2 GTR
Mon Feb 06, 2012 4:44 pm
My motor was doing about the same thing, ended up being an intake valve.
1754 Gatortail Extreme / 35 GTR
Mon Feb 06, 2012 7:51 pm
Mon Feb 06, 2012 9:01 pm
in neutral it should be around 1200 rpms
Mon Feb 06, 2012 9:24 pm
Mon Feb 06, 2012 10:47 pm
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Mon Feb 06, 2012 10:53 pm
Mon Feb 06, 2012 11:05 pm
there is a screw on top of your carb, turn right to rise idle until hits around 1200
Mon Feb 06, 2012 11:10 pm
MMT Moderator
Post Idle problems
Mon Feb 06, 2012 11:13 pm
Turn up the idle first, 800 with stock coils in the water is low.
Tue Feb 07, 2012 4:34 am
Users browsing this forum: Majestic-12 [Bot] and 82 guests
