2003 Kawasaki 27hp will not run
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=26449
Author:  holderfieldshelby [ Mon Feb 06, 2012 12:22 pm ]
Post subject:  2003 Kawasaki 27hp will not run
Hi i have a 2003 Kawi, was on the lake last week motor slowed down and died acted like it ran out of fuel, reached back and grabbed the fuel pump and it was obvious the pump wasnt running, so i replaced the pump this week after checking old pump solid on the battery and got nothing, new pump is on primed up and i realized that there was water in the fuel so i flushed all the fuel lines put fresh fuel in replaced water seperation filter and put new gas in, fuel pump fires right up i can remove top fuel line and it is squirting fuel out of fuel pump when turned on, now, the motor still will not start, i have rebuilt carbureator checked for spark on both cylinders it has a hot spark on both yet will not start acts like it has no fuel, i sprayed starting fluid in it and ran on the fluid for a second then died so i know the motor is fine, what is the deal????? am i missing something????
Author:  holderfieldshelby [ Tue Feb 07, 2012 12:20 am ]
Post subject:  Re: 2003 Kawasaki 27hp will not run
solved the issue hit the intake line with air freed up the needle and seat and she fired right up
