Idle problems
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=26454
Author:  maverick [ Mon Feb 06, 2012 1:57 pm ]
Post subject:  Idle problems
So I have a 36pd 08 model so when I go to engage the clutch it will not idle out, I have to milk the throttle for it to not die looking for any solutions to fix this
Author:  craig [ Mon Feb 06, 2012 1:58 pm ]
Post subject:  Re: Idle problems
What rpm is it idling at?
It should be 1100-1200.
Author:  maverick [ Mon Feb 06, 2012 2:02 pm ]
No it's not it's around 900 or so
Author:  duckduckboom [ Mon Feb 06, 2012 4:18 pm ]
Author:  deltaduckmaster [ Mon Feb 06, 2012 4:44 pm ]
Instead If adjusting your idle with the carb setting adjust by bending arm on governor spring!!
Author:  robertb4wd [ Mon Feb 06, 2012 7:51 pm ]
My motor was doing about the same thing, ended up being an intake valve.
Author:  maverick [ Mon Feb 06, 2012 9:01 pm ]
Author:  duckduckboom [ Mon Feb 06, 2012 9:24 pm ]
in neutral it should be around 1200 rpms
Author:  maverick [ Mon Feb 06, 2012 10:47 pm ]
Author:  WestEndAngler [ Mon Feb 06, 2012 10:53 pm ]
Author:  maverick [ Mon Feb 06, 2012 11:05 pm ]
Author:  duckduckboom [ Mon Feb 06, 2012 11:10 pm ]
there is a screw on top of your carb, turn right to rise idle until hits around 1200
Author:  WestEndAngler [ Mon Feb 06, 2012 11:13 pm ]
Author:  deadbird8 [ Tue Feb 07, 2012 4:34 am ]
Turn up the idle first, 800 with stock coils in the water is low.
