It is currently Sun Jul 13, 2025 11:13 am
Reply to topic  [ 24 posts ]
 Problem Getting on plain
Post Problem Getting on plain
I have a 1760 lowe with a 32 prodive on it. I have the hardest time in the world getting it to plain out. I heard putting pods on the back would help alot. Any idea on this thanks alot..
Mon Dec 19, 2011 6:07 pm
MMT Moderator
Post Re: Problem Getting on plain
Incorrect transom angle?
GTB 1860 w/ 2019 GTR40XD-HO
Mon Dec 19, 2011 6:21 pm
Load?
Trim setting?
Transom heights?
Bottom of boat beat up?
Prop wear?
Mon Dec 19, 2011 6:23 pm
Tell the big guys to get their own boat. I don't know much about that particulr boat, but a 60" wide boat shouldn't have problem getting up if everything else is correct as the other guys have stated
Mon Dec 19, 2011 8:22 pm
I believe the angle is fine it has been the same set up all bought new.. Prop is in good shape and bottom of boat is in good shape. I usually notice it with a load like 3 guys and decoys and gear. A guy has the same setup but has pods on the back and he seems to fly around no problem. I can get it to plane out i just have to get it just right and crank it at exactly the right time...
Thu Dec 22, 2011 2:08 pm
Any help guys?
Tue Feb 07, 2012 3:09 pm
MMT Moderator
Add, Cam, Heads, Exhaust & Mikuni Carb and fly past your buddy holding a single finger :mrgreen:
Tue Feb 07, 2012 3:19 pm
If it didnt do it before and is now doing it, then something has changed in the motor or in the boat. how many rpm's are you pushing? even a 1/4" wear on the prop can have an effect. Is the load balanced? any hooks near the transom?
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Tue Feb 07, 2012 3:35 pm
Check for burnt valves
Or do iron moutain heads with a 36 carb and prop
I gave up mud motors
Tue Feb 07, 2012 3:37 pm
Check your valve lash.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Feb 07, 2012 3:48 pm
I just bought the boat from a guy that had it new. He never put much in the boat when he had it. I have had the valves checked.
Tue Feb 07, 2012 4:43 pm
4100 rpm
Tue Feb 07, 2012 4:44 pm
Bayou Surface Drive
337-351-0362
Tue Feb 07, 2012 4:46 pm
I put pods on a tracker boat last yr. i was running a 29hp kaw. surface drive, that boat wouldnt plain out at all before the pods and after it worked pretty well in very shallow water but still had trouble when water was deep
Tue Feb 07, 2012 5:15 pm
Pods are a waste of money. Bandaide on a bulletwound.
Tue Feb 07, 2012 5:25 pm
MMT Moderator
Tue Feb 07, 2012 6:05 pm
MMT Moderator
What's the transom angle on a lowe boat? What does it need to be for PD's?
If those two numbers match you should be good and start diagnosing other issues.
Tue Feb 07, 2012 6:07 pm
trim will get you within the right transom angle... My boat has a 15* angle IIRC, GT has 20*. I have no issues with mine. A 1760 with a 35 should step a 3 man load, plain and simple.
Bayou Surface Drive
337-351-0362
Tue Feb 07, 2012 7:27 pm
if you are running over 4000 rpm's WOT it sounds like a worn prop or trimmed too deep issue. If the motor is too weak to push the boat it dam sho ain't gonna be running 4000 rpm's in the water, you would prob. be looking at 31-3300 for an underpowered motor.
HOTSAUCE170 wrote:
Tue Feb 07, 2012 7:42 pm
Motor can still turn up with leaky valves, but will not have the power to do anything. I agree with Marcus. If you've checked the lash and it is all good, have a leak down test done.
Tue Feb 07, 2012 7:43 pm
You said 4100 RPM. Thats neutral RPMs right? Set them to 4250 and roll out. If you have a valve lash, or leaky valve the motor without any load on it will NOT have a problem bumping the governor. When you put load on the prop then thats where it will show..
My motor with a rounded Exhaust cam lobe would bumpe 4250 in neutral but couldnt get above 3000 in the water..... See what I am saying.
Bayou Surface Drive
337-351-0362
Wed Feb 08, 2012 7:19 am
Hey guys, what is a leakdown test?
Thanks in advance for answering a question that has probably already been answered 1000X on this board.
Wed Feb 08, 2012 8:32 am
http://www.google.com/search?q=leakdown ... ent=safari
Wed Feb 08, 2012 8:35 am
Thanks, duckduckboom. Should'a thought to google it myself.
Wed Feb 08, 2012 9:16 am
Users browsing this forum: No registered users and 116 guests
