maverick
Joined: Tue Apr 19, 2011 2:02 pm Posts: 64 Location: alabama
 Idle problems
So I have a 36pd 08 model so when I go to engage the clutch it will not idle out, I have to milk the throttle for it to not die looking for any solutions to fix this
_________________ 1748 SDB being pushed by a 36pd
Mon Feb 06, 2012 1:57 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Idle problems
What rpm is it idling at?
It should be 1100-1200.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Mon Feb 06, 2012 1:58 pm |
maverick
 Re: Idle problems
No it's not it's around 900 or so
Mon Feb 06, 2012 2:02 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Idle problems
_________________ You have your whole life to be an idiot, take a day off!
Mon Feb 06, 2012 4:18 pm |
deltaduckmaster
 Idle problems
Instead If adjusting your idle with the carb setting adjust by bending arm on governor spring!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Mon Feb 06, 2012 4:44 pm |
robertb4wd
Joined: Sat Jul 18, 2009 7:18 pm Posts: 1501 Location: Bridge City, Texas
 Re: Idle problems
My motor was doing about the same thing, ended up being an intake valve.
_________________ 1754 Gatortail Extreme / 35 GTR
Mon Feb 06, 2012 7:51 pm |
maverick
 Re: Idle problems
Mon Feb 06, 2012 9:01 pm |
duckduckboom
 Re: Idle problems
in neutral it should be around 1200 rpms
Mon Feb 06, 2012 9:24 pm |
maverick
 Re: Idle problems
Mon Feb 06, 2012 10:47 pm |
WestEndAngler
MMT Moderator
 Re: Idle problems
Mon Feb 06, 2012 10:53 pm |
maverick
 Re: Idle problems
Mon Feb 06, 2012 11:05 pm |
duckduckboom
 Re: Idle problems
there is a screw on top of your carb, turn right to rise idle until hits around 1200
Mon Feb 06, 2012 11:10 pm |
WestEndAngler
MMT Moderator
 Idle problems
Mon Feb 06, 2012 11:13 pm |
deadbird8
 Re: Idle problems
Turn up the idle first, 800 with stock coils in the water is low.
Tue Feb 07, 2012 4:34 am |
