It is currently Fri Jul 11, 2025 11:44 pm
Reply to topic  [ 11 posts ]
 excel 1645swf4 23sd mb
Post excel 1645swf4 23sd mb
17mph top speed w/ me (225). sounds kinda slow..ive ran this boat for 1 1/2 years..is there anything that sounds kinda out of wack or is it just me..ive moved weight around, trim angles..just about to say the hell with it and buy a 35..any sug?
1645excel going slow wit 23mb
Wed Feb 15, 2012 11:06 pm
Post Re: excel 1645swf4 23sd mb
It would haul with a 35 on it! But it still should be doing better than 17 mph with just you in the boat. Has it always done this or did it just start it?
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Thu Feb 16, 2012 12:02 am
since day one it has been like that..i think the boat just way to heavy for that size motor.
Thu Feb 16, 2012 8:00 am
First things first...
Measure your prop.... What does it measure
What RPM's are you turning. In the water and OOW.
Also, stock valves suck. If the above is ok, then it may just be leaky valves
1848 Prodigy
35 GTR
Thu Feb 16, 2012 8:54 am
Sounds about right. To me, a 23 on that hull is a little under powered. Check what the hull is rated for and match it up accordingly with the biggest motor you can afford.
Thu Feb 16, 2012 10:23 am
Yes, stock valves do suck. They could be leaking some. I would also do a compression test in addition to what Barroll said. The 23 for that boat is a little under power, but it should do the job with just one person in the boat. You could always try selling the 23 and getting either a 35 or BD 4500 that has the heads and single Mikuni. Your face with look like this if you done that :D . I won't ever have another motor without Iron Mountain Heads on it. Stock heads just plain suck.
"Drop the Hammer"
Thu Feb 16, 2012 11:55 am
Why not just throw some heads,exhaust and cam on that small block.
Thu Feb 16, 2012 12:38 pm
1848 Prodigy
35 GTR
Thu Feb 16, 2012 12:59 pm
"Drop the Hammer"
Thu Feb 16, 2012 1:25 pm
I was thinking bout putting mods on it but just like yall said all the money i could have tied up in that i could afford a 35. i appreciate all the info
Fri Feb 17, 2012 9:52 pm
I run an old Quachita 1542 flatbottom with waterlogged side flotation and a beat to hell bottom. My 24 Honda Mini Gps'd 25mph with 2 people, weight 197, and 190. You should be running low 20's atleast , with a stock motor and good propeller.
Sat Feb 18, 2012 8:56 am
Profile YIM
Users browsing this forum: No registered users and 101 guests
