It is currently Fri Jul 11, 2025 9:14 pm
Reply to topic  [ 4 posts ]
 Starting issues with 35 HP vanguard
Post Starting issues with 35 HP vanguard
Hi, I have a 35 HP vanguard in a mud boat. Motor was a straight drive and ran fine. I installed a transmission and been having trouble starting. I have to work the throttle a lot to get it to try to start. once it starts it runs fine. Once i installed the tranny the motor is at an angle. Does this have anything to do with it??? I am getting fuel to the carb. Also does the Anti-backfire solonoid have something to do with it. Please help
Thanks HAM :?:
Sat Feb 18, 2012 3:31 am
Post Re: Starting issues with 35 HP vanguard
Does the motor have a mercury switch on it?
Does it crank and run at all or just spin over?
Sat Feb 18, 2012 6:11 pm
Thanks for the response. It doesn't have a mercury switch. I have to pump the gas to get it to start. After that it will start every time. Once I let for several hours it is hard to start again.. I have a feeling that with the angle the engine is at the fuel drains out the carb. once it sits for a while. Is there a spacer to go under the carb. to get it some what close to level?
Sun Feb 19, 2012 5:45 pm
Sounds like an electric fuel pump would be your easiest fix.
Sun Feb 19, 2012 7:06 pm
Users browsing this forum: No registered users and 131 guests
