Starting issues with 35 HP vanguard http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=26867 |
Author: | ham454 [ Sat Feb 18, 2012 3:31 am ] |
Post subject: | Starting issues with 35 HP vanguard |
Hi, I have a 35 HP vanguard in a mud boat. Motor was a straight drive and ran fine. I installed a transmission and been having trouble starting. I have to work the throttle a lot to get it to try to start. once it starts it runs fine. Once i installed the tranny the motor is at an angle. Does this have anything to do with it??? I am getting fuel to the carb. Also does the Anti-backfire solonoid have something to do with it. Please help Thanks HAM ![]() |
Author: | Woodiebuster [ Sat Feb 18, 2012 6:11 pm ] |
Post subject: | Re: Starting issues with 35 HP vanguard |
Does the motor have a mercury switch on it? Does it crank and run at all or just spin over? |
Author: | ham454 [ Sun Feb 19, 2012 5:45 pm ] |
Thanks for the response. It doesn't have a mercury switch. I have to pump the gas to get it to start. After that it will start every time. Once I let for several hours it is hard to start again.. I have a feeling that with the angle the engine is at the fuel drains out the carb. once it sits for a while. Is there a spacer to go under the carb. to get it some what close to level? |
Author: | SmokeEater829 [ Sun Feb 19, 2012 7:06 pm ] |
Sounds like an electric fuel pump would be your easiest fix. |
