Idle problems
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27063
Author:  maverick [ Thu Feb 23, 2012 7:36 pm ]
Post subject:  Idle problems
I have a 36pd which I have just added a mm exhaust I'm having a problem with the idle when the clutch is engaged (this is not in the water ) it will die unless I stay on the throttle but I think my probelm might be the new fuel pump I added I think it's either my putting enough fuel or it's over flowing the carb its rated 1 to 3.5 psi any suggestions on what to do
Author:  duckduckboom [ Thu Feb 23, 2012 7:47 pm ]
Post subject:  Re: Idle problems
Rpms around 1200?
Author:  maverick [ Thu Feb 23, 2012 7:54 pm ]
Author:  duckduckboom [ Thu Feb 23, 2012 8:05 pm ]
why they aftermarket fuel pump?
Author:  richard nagon [ Thu Feb 23, 2012 8:06 pm ]
hows it run at wot.? might have got crude in the fuel curcuit when u changed pump. if u have a primer bulb gently pump it and see what happens. when it starts to die. reset your idle mixture also. what kind of carb. ?
Author:  maverick [ Thu Feb 23, 2012 8:14 pm ]
DDM- it had one on it when I bought It after awhile the wires corroded on the last one so I got another one
Richard - its stock carb
Author:  richard nagon [ Thu Feb 23, 2012 8:19 pm ]
hows it run with wide open throttle. under load.?
Author:  maverick [ Thu Feb 23, 2012 8:23 pm ]
Haven't had then chance to take it out just put the exhaust on tonight
Author:  duckduckboom [ Thu Feb 23, 2012 8:44 pm ]
valve lash good?
Author:  maverick [ Thu Feb 23, 2012 8:48 pm ]
Sorry but what is valve lash ?
Author:  duckduckboom [ Thu Feb 23, 2012 9:13 pm ]
http://www.youtube.com/watch?v=hGkn0jR9RJM
Author:  maverick [ Sat Feb 25, 2012 6:23 pm ]
What should the rpms be when idling
Author:  deadbird8 [ Sun Feb 26, 2012 3:49 am ]
Author:  maverick [ Sun Feb 26, 2012 12:13 pm ]
Ok do when I do have it idling at 1100 it stays at a 1100 for a sec then slowly idles down I think the pump is flooding the carb the pump is rated at 1 to 3.5 psi wht should the rpms be when the clutch isn't ingaged
