maverick
Joined: Tue Apr 19, 2011 2:02 pm Posts: 64 Location: alabama
 Idle problems
I have a 36pd which I have just added a mm exhaust I'm having a problem with the idle when the clutch is engaged (this is not in the water ) it will die unless I stay on the throttle but I think my probelm might be the new fuel pump I added I think it's either my putting enough fuel or it's over flowing the carb its rated 1 to 3.5 psi any suggestions on what to do
_________________ 1748 SDB being pushed by a 36pd
Thu Feb 23, 2012 7:36 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Idle problems
Rpms around 1200?
_________________ You have your whole life to be an idiot, take a day off!
Thu Feb 23, 2012 7:47 pm |
maverick
 Re: Idle problems
Thu Feb 23, 2012 7:54 pm |
duckduckboom
 Re: Idle problems
why they aftermarket fuel pump?
Thu Feb 23, 2012 8:05 pm |
richard nagon
 Re: Idle problems
hows it run at wot.? might have got crude in the fuel curcuit when u changed pump. if u have a primer bulb gently pump it and see what happens. when it starts to die. reset your idle mixture also. what kind of carb. ?
_________________ JUST ANOTHER FARMER ON WELFARE
Thu Feb 23, 2012 8:06 pm |
maverick
 Re: Idle problems
DDM- it had one on it when I bought It after awhile the wires corroded on the last one so I got another one Richard - its stock carb
Thu Feb 23, 2012 8:14 pm |
richard nagon
 Re: Idle problems
hows it run with wide open throttle. under load.?
Thu Feb 23, 2012 8:19 pm |
maverick
 Re: Idle problems
Haven't had then chance to take it out just put the exhaust on tonight
Thu Feb 23, 2012 8:23 pm |
duckduckboom
 Re: Idle problems
valve lash good?
Thu Feb 23, 2012 8:44 pm |
maverick
 Re: Idle problems
Sorry but what is valve lash ?
Thu Feb 23, 2012 8:48 pm |
duckduckboom
 Re: Idle problems
Thu Feb 23, 2012 9:13 pm |
maverick
 Re: Idle problems
What should the rpms be when idling
Sat Feb 25, 2012 6:23 pm |
deadbird8
 Re: Idle problems
Sun Feb 26, 2012 3:49 am |
maverick
 Re: Idle problems
Ok do when I do have it idling at 1100 it stays at a 1100 for a sec then slowly idles down I think the pump is flooding the carb the pump is rated at 1 to 3.5 psi wht should the rpms be when the clutch isn't ingaged
Sun Feb 26, 2012 12:13 pm |
