It is currently Sat Jul 12, 2025 12:41 am
Reply to topic  [ 4 posts ]
 Need advice 35hp MB
Post Need advice 35hp MB
have a stock 35hp vanguard 07' mudbuddy that runs fine but i'm just curious cost and performance wise whats out there....i dont want to spend more then 1k, so i guess what are my options for all yall motor heads...thanks
Tue Feb 28, 2012 10:32 am
Post Re: Need advice 35hp MB
Depending on what ya need I personally like carb, cam, and heads.
Tue Feb 28, 2012 10:36 am
X2 on that. Id do carb and exhaust. It cost a little over 1k but is kinda the basics you need to do other things. Heads on top of that would make you smile for sure
Dead Fowl Custom 1954hd with a GTR
Tue Feb 28, 2012 11:47 am
High flow exhaust will be the base for any future mods, letting the motor breathe and getting rid of the possibility of the stock pipe dropping weld slag into your cylinders.
Heads would eliminate the common problem of stock valves leaking which rob power.
Together these will be ~$1K and give you more power, load carrying and top end. Depending on how well your stock valves are sealing you may see significant increase in power.
'Gifts' in the cylinder make a mess:
Stock valves suck:
Wed Feb 29, 2012 6:24 am
Users browsing this forum: No registered users and 80 guests
