Rocker help and suggestions http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27156 |
Author: | GSUrugger [ Mon Feb 27, 2012 6:32 am ] |
Post subject: | Rocker help and suggestions |
Saturday, was out playing in some shallow flats near the house, and suddenly lost power. after seeing i was blowing raw fuel out of the carb intake, i checked my valve train and discovered i had thrown a pushrod (same one i threw late last year in alabama). upon further investigation, i noticed the probable reason for this was the pivot bolt holding the rocker in had become loose. i reinstalled on the water, set the lash, and promptly threw it again, though i feel the reason for the second time was due to the fact i did not have a shaved socket to re-torque the bolt. I plan on using loctite when i re-install the rocker and set the lash; would this be ok? |
Author: | GSUrugger [ Mon Feb 27, 2012 12:31 pm ] |
Post subject: | Re: Rocker help and suggestions |
anybody wanna weigh in on loctite on the pivot bolt |
Author: | autogateman [ Mon Feb 27, 2012 1:29 pm ] |
yes it will be fine |
Author: | GSUrugger [ Mon Feb 27, 2012 1:33 pm ] |
Thanks. |
Author: | 50fps [ Mon Feb 27, 2012 1:54 pm ] |
I ran a tap down a little farther than what the factory cuts and used socket head cap screws w/ loctite. You'd think a company that brags about their R&D would supply a decent pivot bolt that wouldn't require the customer to go and purchase a thinwall socket or grind one down. |
Author: | Salty Dawg [ Mon Feb 27, 2012 2:18 pm ] |
Author: | 50fps [ Mon Feb 27, 2012 2:25 pm ] |
Author: | GSUrugger [ Mon Feb 27, 2012 2:31 pm ] |
Author: | Salty Dawg [ Mon Feb 27, 2012 3:27 pm ] |
