Another one bits the dust!
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27319
Author:  Beadlejuicejr [ Fri Mar 02, 2012 6:16 pm ]
Post subject:  Another one bits the dust!
Well went ahea an started changing out my case gasket a lil while ago cause it started another bp oil spill lastnight frogging. So I go ahead and pull the camshaft out just to check out the lobes make sure everything is in order hole I'm in there, well what do I get to find but yet another block F'ed up cam bushing GONE camshaft end screwed. Well, that makes two block in say a year. Don't get better than that
Author:  downdabayou [ Fri Mar 02, 2012 6:21 pm ]
Post subject:  Re: Another one bits the dust!
Damn how many hours on this block
Author:  OwenDickeson [ Fri Mar 02, 2012 6:31 pm ]
Who built the motor?
Author:  Beadlejuicejr [ Fri Mar 02, 2012 6:57 pm ]
I couldn't tell you how many hrs the hrs don't go up on it I'd say somewhere about 100 or so
I built the motor with care oiled everything up soaked it before putting it in. The first one that did it was a stock motor that never been touched
Author:  Beadlejuicejr [ Sat Mar 03, 2012 2:43 am ]
They are just Shimed with I'm assuming same shims everyone uses
Author:  Calen [ Sat Mar 03, 2012 8:02 am ]
If your running the set of heads you got from me it's Definitely not spring tension.
Author:  pooldoo73 [ Sat Mar 03, 2012 10:27 am ]
That sucks. How long would it have run like that if u wouldn't have decided to change the case gasket when u did?
