Rev limiter install on GTR23 help http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27352 |
Author: | dguidry [ Sat Mar 03, 2012 9:12 pm ] |
Post subject: | Rev limiter install on GTR23 help |
Team Camon was so generous to help me install my rev limiter at the SETX 2012 landing but he didn't get it right. My engine is non cdi. Where do you connect the three rev limiter wires? |
Author: | dfou [ Sat Mar 03, 2012 9:27 pm ] |
Positive negative and the kill wire, usually green if I recall correctly |
Author: | dguidry [ Sat Mar 03, 2012 9:37 pm ] |
Post subject: | Re: Rev limiter install on GTR23 help |
Author: | dfou [ Sat Mar 03, 2012 9:47 pm ] |
For a MB you hook the red wire to the relay that is hot when the key is on not sure which wire that is on your motor but if you have a meter u can find it. The black goes to ground usually one of the small bolts on the starter and the green should tie into your kill wire which is also normally green |
Author: | dguidry [ Sat Mar 03, 2012 9:50 pm ] |
Author: | dfou [ Sat Mar 03, 2012 9:53 pm ] |
Check the back of the key switch to find the wire then trace it to the pigtail and tie in there |
Is the rev limiter just not getting power? Faulty rev limiter? |
Author: | dguidry [ Sun Mar 04, 2012 8:42 am ] |
Author: | Team Camo [ Sun Mar 04, 2012 9:03 am ] |
That's how I hooked it up. Red to the accessory wire from the switch (only hot while key is "on" black wire to ground, green wire to the diode stud on #1 cylinder. Everything was hooked up correctly, but I could still run it up to 4470-4500 rpm without it cutting out. ***note*** this is the newer style box & rated for 4400 (I believe) to 4600. |
Author: | dguidry [ Sun Mar 04, 2012 9:08 am ] |
Author: | Team Camo [ Sun Mar 04, 2012 9:13 am ] |
Hard to say without putting another tach on there to check. That exhaust screams right in ya face, so I had a hard time going by sound ![]() |
Author: | BoatDR [ Mon Mar 05, 2012 9:59 am ] |
That rev limiter "kick in" at 4570. |
Author: | Team Camo [ Mon Mar 05, 2012 2:33 pm ] |
Well there ya go, I was scared to take it up that high. If I blow my stuff up, oh well---but I aint about to push somebody else's that hard, especially a lawyer's. ![]() |
Author: | freonjohn [ Mon Mar 05, 2012 4:05 pm ] |
just put a mikuni on my 23hp gdsd today. rev limiter kicks in right at 4500 rpms just like boatdr said. At least i know now the tiny tach is reading pretty accurate |
Author: | mizzippi jb [ Mon Mar 05, 2012 6:32 pm ] |
Author: | BoatDR [ Mon Mar 05, 2012 7:55 pm ] |
