It is currently Wed Sep 17, 2025 11:55 am
Reply to topic  [ 10 posts ]
 Bad Gas, Carbs clogged!
Post Bad Gas, Carbs clogged!
any suggestions on fluids/ liquids that I could add to the gas to try and clean out the carb with out taking the carb off to clean?
Tue Jun 23, 2009 7:01 am
Post Re: Bad Gas, Carbs clogged!
Soapy Water!! :o
Tue Jun 23, 2009 7:04 am
SeaFoam - mechanic in a can.
Tue Jun 23, 2009 10:38 am
You can try Sea-Foam or any of the commercial additives.
But odds are if it is gummed up it is going to stay that way.
can you get it to run at all or I guess I should say what exactly is it doing?
Tue Jun 23, 2009 1:15 pm
She will run but, when I am in the water and put her in gear she trys to die. I have to rev up the rpms a little to get her to not die.
Tue Jun 23, 2009 9:05 pm
What is your idle RPMs? Maybe turning it up a little might help.
18x48 Charles Leonard / 36PD
Tue Jun 23, 2009 9:15 pm
where is the best place to buy seafoam
aucoin 18'x52" bateau w/ 35GTR
Wed Jun 24, 2009 2:21 pm
Wed Jun 24, 2009 3:34 pm
I think the ethanol is the culprit. Pulled the carb off of a lawn mower the other day and it was all funked up. Brake cleaner barely touched the stuff.
Buddy of mine said that Chevron (I think) is the only one that does not add ethanol to their gas. Suggested buying all small engine gas from them to avoid the problems associated with gummed up carbs.
OneBigAssMistakeAmerica
Wed Jun 24, 2009 4:38 pm
Wed Jun 24, 2009 4:54 pm
