It is currently Fri Jul 11, 2025 9:06 pm
Reply to topic  [ 34 posts ]
 Kohler 27 not starting
Post Kohler 27 not starting
I just bought a used 27 Beavertail with low hours. I had it shipped. I cannot get it started. It will turn over but not start. I pulled the spark plug and there was some black on it, smelled like gas, maybe flooded. Is there anything to look for as of why it's not starting. I don't have a primer pump on my fuel line, could that be why?
Tue Mar 06, 2012 6:18 pm
Post Re: Kohler 27 not starting
is your kill switch on?
Tue Mar 06, 2012 6:19 pm
How can you tell? It's just a little button. I pushed it in. I first though I had the killswitch wire plugged in the wrong female so I switched it , while the key was still on like a dumbass and it sparked. Now it wont do anything. Like I might have fried starter.
Tue Mar 06, 2012 6:26 pm
i am not sure what style kill switch beavertail uses. Are you getting a spark to your spark plug?
Tue Mar 06, 2012 6:29 pm
I'll have to check after I get the starter issue figured out now
Tue Mar 06, 2012 6:31 pm
Does not having a primer ball make an issue? Figured I didn't need one bc of fuel punp
need one, no. does it help, yes.
Tue Mar 06, 2012 6:34 pm
Maybe that's what it is. I can't figure it out
Tue Mar 06, 2012 6:37 pm
What do u think about the spark plug
Tue Mar 06, 2012 6:41 pm
its hard to tell from picture. once you get it turning back over. plug the spark plug into the boot and hold it by the RUBBER, then press the threads of the spark plug against the heat shield and turn it over. you should see if it is sparking
Tue Mar 06, 2012 7:04 pm
10-4. Do you think me plugging the wrong wire into the killswitch could have blown the starter?
Tue Mar 06, 2012 7:16 pm
can't say man. if you take it off and bring it to a autoparts store they can bench test it
Tue Mar 06, 2012 7:38 pm
Alright thanms
Tue Mar 06, 2012 8:22 pm
If the sparks plug smells like gas and is wet, the primer bulb isn't the issue.
You are getting fuel.
Make sure the kill switch is in the right slot, I took mine out and put it back in the wrong spot, it would turn over but not fire. Scared the shit outta me in the swamp.
Tue Mar 06, 2012 8:56 pm
Yeh I plugged the killswitch into the white wire like Beavertail says. It's when I plugged it into the yellow and it sparked and won't even turn over now
Wed Mar 07, 2012 4:39 am
I just realized something. If I dont have the red killswitch spiral wire not hooked onto the killswitch button will it not start on a Beavertail?
Wed Mar 07, 2012 8:01 am
Yes you have to have the kill lanyard hooked up for it to start
Wed Mar 07, 2012 8:14 am
Yep I feel like an idiot
Wed Mar 07, 2012 8:32 am
Do you know why it was the first thing i asked you? We have all been down that road. Remember to open the vent on your gas tank also. it will have you scratching your head if you don't
Wed Mar 07, 2012 8:39 am
Lol yeh I did that. I'm going to go have a test done on the starter now
Wed Mar 07, 2012 8:48 am
Mine got pulled out in the middle of a swamp and left me paranoid and searching why my motor wouldn't start
Wed Mar 07, 2012 9:29 am
Wed Mar 07, 2012 11:18 am
had a guy call me one night to come get him. rode out told him i would fix his motor on the spot for 100 dollars. he said okay and i told him to plug his kill switch in. i never would/will except the money but i remind him all that he owes me a 100
Wed Mar 07, 2012 11:39 am
Checked out starter and it's fine. Now I need to find out what I screwed up when plugging in the wrong killswitch wire with key on.
Wed Mar 07, 2012 12:18 pm
Look for an inline fuse
Wed Mar 07, 2012 12:22 pm
Yeh didn't see any
Wed Mar 07, 2012 1:11 pm
Hook the starter back up an put a multimeter to it
Wed Mar 07, 2012 1:53 pm
Where do I connect multimeter?
Wed Mar 07, 2012 1:59 pm
From the stud with bigger red wire(+) and ground negative on the block
Wed Mar 07, 2012 2:15 pm
10-4 I'll try it when I get home. Thanks for the help.
Wed Mar 07, 2012 3:21 pm
Found the problem. There was a fuse on one of the wires that blew. Gonna pick one up tomorrow
Wed Mar 07, 2012 5:55 pm
That's what we were asking, if the lanyard was hooked up, not if wires were connected.
I pulled mine out in the swamp and hooked it back up, got ready to crank my motor and it would turn over but wouldn't start. After awhile I called someone to get me and my phone was dead :cry:
Got panicked but after I calmed down I realized it was hooked up wrong.
Wed Mar 07, 2012 8:53 pm
Does it have to be a 30 amp fuse 32v? I can't find them anywhere. Thats the size that can out
Thu Mar 08, 2012 4:22 pm
Found a 20 amp fuse. Started right up.
Thu Mar 08, 2012 5:45 pm
Users browsing this forum: Google [Bot] and 128 guests
