It is currently Sun Jul 13, 2025 9:03 am
[ 8 posts ] |
nickel377
 Occasionall Sputtering
23HP Mud Buddy mini. I have it with a upgraded BPS Mikuni Carb kit, Single crossover and Stainless exhauste. I ran the motor a few days ago wideopen for an hour. At one point the motor started sputtering or skipping like it was not getting gas. I have since then changed the spark plugs, new fuel filter, and cleaned the carb. Took the motor out today and still the occasionall skip. The motor cranks fine and ideals fine only happens when running on the water. Wondering if anyone has any ideas on what elese I can do or check to fix. I will be taking the fuel out of the tank because it is not ethonal free but did use stabil. will put ethonal free gas in it and run it to see if that helps. Any sugestions would be great. thanks.
Tue Mar 13, 2012 8:17 pm |
crittergitter
Joined: Wed Aug 31, 2011 8:32 am Posts: 277 Location: Mineola, Tx
 Re: Occasionall Sputtering
Make sure your vent is open on tank.
_________________ Supporting our Troops. United States Navy 13 yrs proud E-6 Petty Officer First Class Aircrew Survivial Equipmenman, Certified Land and Water Survival Instructor MTS, and EMT. 1650 Lake sport 36PD.
Tue Mar 13, 2012 9:59 pm |
Woodiebuster
Was it hitting the rev limiter?
Tue Mar 13, 2012 10:30 pm |
nickel377
I did check the vent it was ok and open. I was ruining 3900 rpms would that still effect rev limiter.
Wed Mar 14, 2012 3:55 am |
eljefe
Joined: Thu Jan 13, 2011 7:32 am Posts: 5210 Location: Beaumont Texas
Che k your fuel filter...and fuel lines...do you have a water seperater...check it all.
_________________ You can't see the sunrise if your eyes are closed. dying aint much of a livin....
Black ops IITX marshstalker
1840 WC www.wccustomboats.com fuel injected 25 GTR
Wed Mar 14, 2012 6:26 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
Are you losing a prime?
_________________ You have your whole life to be an idiot, take a day off!
Wed Mar 14, 2012 6:30 am |
Duckdon
Joined: Sat Apr 24, 2010 3:32 pm Posts: 407 Location: Chugiak, Alaska
Switch to premium fuel, make sure you have no air leaks in the fuel lines after you remove all the quick connects on the fuel line. Make sure the fuel tank fuel pickup tube is on the bottom of the tank. Do all the other stuff the guys above listed. Try some Sea Foam in the fuel for a couple tanks. Good Luck Duckdon
Wed Mar 14, 2012 8:29 am |
nickel377
Thanks for the ideas will try them this weekend.
Thu Mar 15, 2012 5:51 am |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 105 guests |
