It is currently Fri Jul 11, 2025 9:00 pm
Reply to topic  [ 13 posts ]
 Pd starting in gear
Post Pd starting in gear
36 pd. it's starting in gear without the clutch engaged. It is just barely catching, it makes a pretty loud screach. The clutch still engages just like it should, I unplugged the momentary switch to rule that out but it still is catching.
This just happened suddenly the other night on the river.
Any ideas to try before I call kp tomorrow?
Mon Mar 12, 2012 5:01 pm
Post Re: Pd starting in gear
check the bottom wires on the switch
Mon Mar 12, 2012 5:18 pm
Sounds like the clutch is bad.
Check the tension bands to see if any are bent/twisted (the ss straps underneath the bottom of the clutch that attach the clutch to the to adaptor that goes to the lower unit drive shaft).
Mon Mar 12, 2012 5:25 pm
boatDR, do you sell clutches for PD, Gt's and MB's? And if so, a general idea on price? Thanks.
HOTSAUCE170 wrote:
Mon Mar 12, 2012 5:47 pm
Wires and connections all look good from what I can see.
The straps all look good. They all have a bend in them but it looks like that is how it's made.
Mon Mar 12, 2012 5:51 pm
Where should the green wire go that comes out of the clutch engagement switch? It is not hooked up on the motor side.
Mon Mar 12, 2012 5:57 pm
Mon Mar 12, 2012 6:07 pm
Mon Mar 12, 2012 6:09 pm
Not sure this pic will work. You can see then bent bands here.
Mon Mar 12, 2012 6:15 pm
Bent tension bands = bad clutch.
Must be replaced.
Mon Mar 12, 2012 6:21 pm
And judging from what I see there. Any chance you raced the rpm's up and shifted it into gear? That sure looks like what happens when you shift a motor into gear at too high of rpm's.
Mon Mar 12, 2012 6:23 pm
That could be the case, the motor was running bad at one time and it needed a little extra acceleration to keep it from dying when going in gear. That is fixed now though.
Looks like it will be a new clutch.
I really appreciate the quick replies an help!
Mon Mar 12, 2012 6:31 pm
KP will cut you a real deal on one. Cost plus cost again devided by 2 and multiply by three plus tax. Sounds about right... :roll:
Oh, forgot the 65 dollars for shipping and 10 dollars for handleing.... :lol:
Wed Mar 14, 2012 12:07 pm
Users browsing this forum: No registered users and 123 guests
