It is currently Fri Apr 10, 2026 5:44 pm
[ 3 posts ] |
JD
 compression
I am finally getting her ready for the water. I put some hours on her in the drive way. I did a compression test . between 200 and 210 on 5 checks on each cyl. If you recall I had to rebuild due to a cam failing with just 1 hour on the water. We went with black water 20 thou over pistons, rods and cam. I am running evt roller rockers and springs.I had the flywheel balanced. Heads done by Harahan auto with over sized Manley valves.
It runs smooth to 5000 rpm in the driveway.
I will try to get her wet this week end and report back.
What kind of compression are you getting and what mods have been done. JD
| Tue Jun 23, 2009 6:46 am |
Gator Guy
Joined: Tue Jan 13, 2009 4:53 pm Posts: 457 Location: Loreauville
 Re: compression
I was seeing the same when mine ran, LOL.
| Tue Jun 23, 2009 11:27 am |
50fps
 Re: compression
170/155 on the compression.
Heads are shaved .050 w/5 angle valve job and ported/polished/shimmed.
Stock carb w/ 142-148 jets, stock intake.
BPS crossover.
45cam, stock rockers and pushrods.
| Tue Jun 23, 2009 7:30 pm |
[ 3 posts ] |
