It is currently Sat Jul 12, 2025 4:56 pm
Reply to topic  [ 7 posts ]
 40 Hp. Yamaha 2 Stoke
Post 40 Hp. Yamaha 2 Stoke
Went to run the flat this weekend and im having a problem. Run wide open from launch for over 6 miles before I came off the gas to slow down for a guy fishing. When I went to get back up and run, the motor comes out the hole great, but soon starts to loose power and slow, ends up almost to a crawl while your still supposed to be running wide open. Any ideas guys?
Team Arc Angel Bowfishing
Sun Mar 18, 2012 11:02 pm
Post Re: 40 Hp. Yamaha 2 Stoke
trash in the carbs maybe
also check your compression
i had a suzuki 75 do as you say oneday when it cracked a piston and lost all compression
I gave up mud motors
Sun Mar 18, 2012 11:09 pm
I hope its not the carbs....just spent close to 1000$ on new set
Sun Mar 18, 2012 11:10 pm
trash in a jet could do it though
does it idle good?
or is it hard to start, idle
Sun Mar 18, 2012 11:16 pm
ethanol fuel will destroy the inside of the fuel line and cause lil bits of rubber and plastic to get into the carbs...a new fuel line, clean carbs, and install inline fuel filter
Mon Mar 19, 2012 1:47 pm
Have inline filter brand new, got new fuel line last week, but it has always idled ruff even before the new carbs.
Mon Mar 19, 2012 6:35 pm
Are the jets adjusted correctly? I have a 99 40 yam and if they are not spot on with the service manual and all seals are good, you will have issues, i did. Also check air/fuel mixture
1848 GTB, 36 PD w/ FPR
Fri Mar 23, 2012 3:36 pm
