is there a difference
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=27771
Author:  Hobbs081828 [ Mon Mar 19, 2012 10:01 am ]
Post subject:  is there a difference
Might be a stupid question but is there a difference in heads on vertical shaft motor vs horizontal shaft motor
Author:  Calen [ Mon Mar 19, 2012 10:03 am ]
Post subject:  Re: is there a difference
they are the same
Author:  Hobbs081828 [ Mon Mar 19, 2012 12:12 pm ]
thought I had a set for a 23 but they are actually off a 18 can they work on a 23 with machine work done?
Author:  Puddle jumper [ Mon Mar 19, 2012 9:06 pm ]
Lawnmower racers use 16 hp heads on the 18 for better compression. There is a little machine work involved but it must be worth it, alot of 'em do it. Not sure wether its the same for 18 to 23. None of the engines listed share the same block but they do share parts.
Author:  Hobbs081828 [ Tue Mar 20, 2012 5:47 am ]
Any recommendations on who to talk to on finding out what machine work would be needed .. from the reading I did it seemed that bolt pattern will work but no luck on what would need to be done
