It is currently Sun Jul 13, 2025 8:49 am
Reply to topic  [ 14 posts ]
 submerged go-devil PLEASE help!
Post submerged go-devil PLEASE help!
whats up guys.
hit a stump and sank my boat tonight.. 6.5 go-devil was completely submerged for about five minutes before i pulled it up. I havent tried starting it up yet, I replaced the gas and the oil so far, but still afraid to try and pull start it. what else should i do before i give it a shot?? Is there any hope for me at all?? this motor has been my baby for 5 years.
Thanks alot folks
Mon Apr 02, 2012 9:53 pm
Post Re: submerged go-devil PLEASE help!
Crank that baby up
Mon Apr 02, 2012 9:55 pm
Put it in a big bag of uncooked rice :D
1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Mon Apr 02, 2012 9:58 pm
Pull the spark plugs and roll the engine over to make sure there is no water on top of the piston! Thats about all else I can think of!
Edit- flush out the carb with fresh fuel also!!
Mon Apr 02, 2012 9:59 pm
I did this once with a buddy. Be sure to take plugs out and turn it over a few times until water quits spitting out then put plugs back. Drain the carb and then pump with new gas and crank it for a minute and then shut it off and put new oil in it again and if the oil is still milky keep changing until no more whiteness at all! And that should be it we had to change oil about 6 times but he has a 27. Everything should be fine as long as you change oil and get new plugs.
27 GDLT pushing a War Eagle 1542
Lots of WD40. Pull spark plug make sure there is no water in your cylinders. Water will get everywhere, maybe even shake it around a little. Then replace oil til it's no longer getting lighter. (that's if you missed some water)
EDIT: got errored out of MMT and you bastards beat me to it!
Mon Apr 02, 2012 10:23 pm
Run diesel through it, pull the plugs and bump it, keep doin it till the water is gone
Mon Apr 02, 2012 11:09 pm
There is very little to one of these motors at all, you can take it apart with a 7,8,&10mm nut driver basically.
I would
1. Drain the oil and flush it out once or twice.
2. Drain the tank out really well ( I would probly take it off and blow it out with an air compressor)
3. Take off the air filter cover and intake manifold (8mm) to get to the float bowl easier, remove that bolt on the bottom and dry out the carb and bowl (I think it is 5/8 but cant remember off the top of my head)
4. Pull your spark plug off and pull the recoil several times to blow any water out of the cylinder.
5. Give it all time to dry out Re Gas and Oil that bitch and don't look back.
Mon Apr 02, 2012 11:33 pm
B. MacDonald
Tue Apr 03, 2012 5:50 am
haha thanks yall
Tue Apr 03, 2012 8:29 am
I'd go with the rice. It worked on my iPhone when this happened...
I am here: http://maps.google.com/maps?ll=30.714823,-88.105830
Tue Apr 03, 2012 9:03 am
No dont put diesel in it, it will swell the gaskets. thats old school and dumb.
Seafoam it after the first few oil changes. and run some in the fuel.
Tue Apr 03, 2012 9:45 am
1436 Lowe
Wed Apr 04, 2012 12:40 pm
Negative ghost rider change thd oil change the gas and don't look back
"washed" mines three years ago according to COCO
Wed Apr 04, 2012 5:25 pm
Users browsing this forum: Majestic-12 [Bot] and 97 guests
