It is currently Sun Jul 13, 2025 9:21 am
Reply to topic  [ 6 posts ]
 Clutch engagement
Post Clutch engagement
At what rpm does it start ta hurt a clutch when puttin er in gear?
Sun Apr 08, 2012 7:33 pm
Post Re: Clutch engagement
Anything over idle is not good.
Take it from me I just had to replace my input shaft on the lower unit and splined coupling. Both were rounded out.
And I don't do it that often. 285 hours on the unit.
At the shop where I get my parts they had boxes of input shafts and splined coupling that were rounded out.
Its not made for that.
Sun Apr 08, 2012 7:40 pm
Ok. Dat don't help. What's yer idle speed? Some guys run em higher then others. What dictates off idle? 1200? 1300? 1500???
Sun Apr 08, 2012 7:49 pm
Idle should almost always be 1000-1300 rpm, depending on the setup. In most cases, 1200-1250.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Apr 08, 2012 8:00 pm
Get out there and idle it down on the water as low as it will go before it chokes out under a load.
My 24 Honda won't go below 1200 very well, but I have friends with 23's that can go 800-900
Sun Apr 08, 2012 8:17 pm
Got it. Thanks y'all. I can set er round or a bit lower no prob. Just heard a guys burnin clutches. Didn't wanna have probs.
Sun Apr 08, 2012 8:32 pm
Users browsing this forum: Majestic-12 [Bot] and 121 guests
