It is currently Sat Jul 12, 2025 7:07 pm
[ 6 posts ] |
Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
 Clutch engagement
At what rpm does it start ta hurt a clutch when puttin er in gear?
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Sun Apr 08, 2012 7:33 pm |
naj
Joined: Fri Jan 22, 2010 8:40 pm Posts: 1620 Location: Larose, Louisiana
 Re: Clutch engagement
Anything over idle is not good.
Take it from me I just had to replace my input shaft on the lower unit and splined coupling. Both were rounded out.
And I don't do it that often. 285 hours on the unit.
At the shop where I get my parts they had boxes of input shafts and splined coupling that were rounded out.
Its not made for that.
_________________ 18' X 48" Center Console Sportsman Fab with a Yamaha F70LA 18' X 48" Center Console Sportsman Fab Dragging a 36hp ProDrive 15' X 42" Sea Arch with a 27hp ProDrive
Sun Apr 08, 2012 7:40 pm |
Podcast
 Clutch engagement
Ok. Dat don't help. What's yer idle speed? Some guys run em higher then others. What dictates off idle? 1200? 1300? 1500???
Sun Apr 08, 2012 7:49 pm |
Team Camo
Idle should almost always be 1000-1300 rpm, depending on the setup. In most cases, 1200-1250.
Sun Apr 08, 2012 8:00 pm |
Woodiebuster
Get out there and idle it down on the water as low as it will go before it chokes out under a load.
My 24 Honda won't go below 1200 very well, but I have friends with 23's that can go 800-900
Sun Apr 08, 2012 8:17 pm |
Podcast
 Clutch engagement
Got it. Thanks y'all. I can set er round or a bit lower no prob. Just heard a guys burnin clutches. Didn't wanna have probs.
Sun Apr 08, 2012 8:32 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 87 guests |
