mikuni carb on 27hp kohler... http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=28516 |
Author: | Da-Cajun-Angla [ Tue Apr 17, 2012 11:40 am ] |
Post subject: | mikuni carb on 27hp kohler... |
i did a search and came up with a Mikuni Flat Slide TM Series 4-Stroke Carburetor - 33mm TM33-8012 i dont know too much about this stuff so i just want to make sure im getting the correct one...is there a kit too, or is this all i need? i found one for 210 bucks on amazon...pardon my dumbassness ![]() http://www.amazon.com/Mikuni-Slide-Seri ... B001AI3JYA |
Author: | Da-Cajun-Angla [ Tue Apr 17, 2012 11:46 am ] |
Post subject: | Re: mikuni carb on 27hp kohler... |
what about the nikki carbs? |
Author: | cb5331 [ Tue Apr 17, 2012 11:52 am ] |
You'll need the intake for the 30hp kohler (and should port and semi-Polish, you want the bridge ground down to a knife point), an intake adapter, air filter, and throttle cable. Evt used to sell the kits and it is not much cheaper to put together yourself. Try giving them a call. |
Author: | cb5331 [ Tue Apr 17, 2012 11:55 am ] |
You will also have to figure out a way to lock out the governor or tear the motor down and remove the governor shaft and gear. As far as I know they don't offer a Rev limiter that works with the coils on the kohler (that could be false, but I was not offered one and could not find one). |
Author: | pooldoo73 [ Tue Apr 17, 2012 6:41 pm ] |
Why would u want the bridge to b ground down to a knife point? |
Author: | cb5331 [ Tue Apr 17, 2012 6:48 pm ] |
Probably because the adapter sits directly over it and it would cause quite a dead spot. Lots of guys did this with the Briggs intakes also. |
Author: | pooldoo73 [ Tue Apr 17, 2012 7:11 pm ] |
Cool. Just asking because there is a huge dead spot on the Briggs mikuni adapter also and was thinking that it caused some flow issues that could be transitioned quite a bit. |
Author: | Da-Cajun-Angla [ Fri Apr 20, 2012 9:13 am ] |
thanks for the info cb! |
