It is currently Fri Jul 18, 2025 12:07 am
Reply to topic  [ 8 posts ]
 mikuni carb on 27hp kohler...
Post mikuni carb on 27hp kohler...
i did a search and came up with a Mikuni Flat Slide TM Series 4-Stroke Carburetor - 33mm TM33-8012
i dont know too much about this stuff so i just want to make sure im getting the correct one...is there a kit too, or is this all i need? i found one for 210 bucks on amazon...pardon my dumbassness :D
http://www.amazon.com/Mikuni-Slide-Seri ... B001AI3JYA
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Tue Apr 17, 2012 11:40 am
Post Re: mikuni carb on 27hp kohler...
what about the nikki carbs?
Tue Apr 17, 2012 11:46 am
You'll need the intake for the 30hp kohler (and should port and semi-Polish, you want the bridge ground down to a knife point), an intake adapter, air filter, and throttle cable. Evt used to sell the kits and it is not much cheaper to put together yourself. Try giving them a call.
Tue Apr 17, 2012 11:52 am
You will also have to figure out a way to lock out the governor or tear the motor down and remove the governor shaft and gear. As far as I know they don't offer a Rev limiter that works with the coils on the kohler (that could be false, but I was not offered one and could not find one).
Tue Apr 17, 2012 11:55 am
Why would u want the bridge to b ground down to a knife point?
18'x54"CC Hanko/ 36PD
Tue Apr 17, 2012 6:41 pm
Probably because the adapter sits directly over it and it would cause quite a dead spot. Lots of guys did this with the Briggs intakes also.
Tue Apr 17, 2012 6:48 pm
Cool. Just asking because there is a huge dead spot on the Briggs mikuni adapter also and was thinking that it caused some flow issues that could be transitioned quite a bit.
Tue Apr 17, 2012 7:11 pm
thanks for the info cb!
Fri Apr 20, 2012 9:13 am
Users browsing this forum: Majestic-12 [Bot] and 119 guests
