It is currently Thu Jul 17, 2025 8:11 pm
[ 6 posts ] |
Tnquackerwhacker
 35 MB Questions
I bought a '09 motor with 110 hours on it. The motor idles high and is slow out of the hole. Once it gets on plane it runs about as well as the rest. The previous owner said he tried to adjust the idle on the carb but it took away top end speed. The guys at Mudbuddy said it could be the throttle srping itself. Anybody else have any ideas on the issue?
_________________ 1852 Phowler Extreme w/ 36PD
Thu Apr 19, 2012 6:04 am |
deadbird8
 Re: 35 MB Questions
RPMs at Idle? WOT out of the water? WOT in the water?
Fri Apr 20, 2012 4:59 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: 35 MB Questions
A worn prop can also give it the slow holeshot but will still run top End about the same. Once you get your Rpms in range it should be easy to tell
_________________ You have your whole life to be an idiot, take a day off!
Fri Apr 20, 2012 5:56 am |
Tnquackerwhacker
 Re: 35 MB Questions
I will check the rpm's tonight. I know at WOT in the water it was 3580 Wednesday. The prop is a new tiger big blade.
Fri Apr 20, 2012 6:49 am |
duckduckboom
 Re: 35 MB Questions
That's low. I am not postive on what a mb should be but it is definatly higher than that. Also 15 minutes in sand can destroy a prop
Fri Apr 20, 2012 7:33 am |
Tnquackerwhacker
 Re: 35 MB Questions
Yeah I thought it seemed low, but I've just had it on the boat for a couple weeks. Maybe the throttle cable isn't allowing the carb to open all the way? Yeah, I know the sand can wreck one but its a rock bottom lake I have ran it in so I would definitely feel if I hit the bottom.
Fri Apr 20, 2012 9:15 am |
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 97 guests |
