It is currently Mon Jul 14, 2025 12:59 am
[ 3 posts ] |
outdoorsman.rc
Joined: Sun Oct 23, 2011 6:29 pm Posts: 58 Location: WadBoo Swamp, South Carolina
 Mikuni Problems
I have a 35GDSD and I just installed a marsh mellow X exhaust and a single 45mm mikuni, and I'm having a little trouble with it. When I'm at idle in the water and I give it full throttle it will spit and sputter and will shut off. But if I give it about half throttle and wait until the boat gets on plane and then give it full throttle it runs fine. My mechanic said that we might need to rejet the carb. What is the difference between a 42 and a 45mm mikuni. BPS sells the 42mm now, and Andy aka the BoatDr says the 42mm is a little bit better. I just wanted to get some more info from you guys and see what everyone thinks I should do. Thanks
_________________ 35GDSD Pushing a 1654 GDSD Boat with Single Mikuni and MM X Exhaust
Wed Apr 25, 2012 6:25 pm |
richard nagon
 Re: Mikuni Problems
set ur idle at 1200 rpms and than set your acc. pump. than do your pilot and main jet settings
_________________ JUST ANOTHER FARMER ON WELFARE
Wed Apr 25, 2012 7:00 pm |
BoatDR
 Re: Mikuni Problems
Did you get that accelerator pump working?
If so, what was clogged?
Thu Apr 26, 2012 7:22 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 70 guests |
