prdrive rpm http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=28805 |
Author: | Hershey [ Fri Apr 27, 2012 10:15 am ] |
Post subject: | prdrive rpm |
whats the recommended rpm range to run on the prodrive with all the mods done to it running a stock prop |
Author: | MaXXis85 [ Fri Apr 27, 2012 10:22 am ] |
Post subject: | Re: prdrive rpm |
What is "all the mods"? |
Author: | mizzippi jb [ Fri Apr 27, 2012 1:09 pm ] |
cdi motor? High rev coils? |
Author: | Hershey [ Fri Apr 27, 2012 6:57 pm ] |
port&polished new pistons bord over new cam push rods mikuni carb im kinda new at this work with me im not sure if its cdi or high rev coils |
Author: | mizzippi jb [ Fri Apr 27, 2012 7:23 pm ] |
do you have a marine grade engine(cdi) or a regular briggs vanguard with a rev limiter installed? |
Author: | Hershey [ Fri Apr 27, 2012 7:36 pm ] |
Reg Briggs but no rev limiter |
Author: | mizzippi jb [ Fri Apr 27, 2012 7:39 pm ] |
you need to get a rev limiter put on it. 4600 is what I have on mine. prob. looking at 43- 4400 wide open in the water with your setup. |
Author: | Hershey [ Fri Apr 27, 2012 7:56 pm ] |
p |
Author: | muddiejeep [ Fri Apr 27, 2012 9:43 pm ] |
who did you buy the motor from? it has a bb mikuni adapter on it. I would keep it under 4500 rpm. Just be careful running a givashiter. |
Author: | Hershey [ Fri Apr 27, 2012 9:53 pm ] |
One of my buddies out of Morgan city he told me keep it around 4200 but I just wanted to see what everyone else was running with mods done to their motors What is a givashifter |
Author: | Woodiebuster [ Fri Apr 27, 2012 10:02 pm ] |
less RPM = longer life Personally I wouldnt run it above 4300, 4400 MAX |
Author: | Hershey [ Fri Apr 27, 2012 10:11 pm ] |
Thanks fellas |
Author: | muddiejeep [ Fri Apr 27, 2012 10:14 pm ] |
Author: | Hershey [ Sat Apr 28, 2012 5:20 am ] |
Oh dam that's not good this thing got to last me at least another 2-3 yrs I always been the type I don't run real hard but if I get in a bind the extra juice is thier but Monday a rev limiter goin on |
Author: | mizzippi jb [ Sat Apr 28, 2012 5:58 am ] |
man you need the cable braces for that carb. It goes on the side of the valve cover and holds the cable in place. I honestly don't know how it works without it. |
Author: | mizzippi jb [ Sat Apr 28, 2012 5:59 am ] |
nevermind, just looked at the first pic. never seen one like that on the tiller handle. |
Author: | cb5331 [ Sat Apr 28, 2012 8:27 am ] |
Post subject: | Re: Re: prdrive rpm |
Author: | rangerman28 [ Mon Apr 30, 2012 11:16 am ] |
I am running 4400 rpm on a stock motor. Don't be scared u can push the Rpms if the motor was built correct |
Author: | duckduckboom [ Mon Apr 30, 2012 3:36 pm ] |
Author: | deltaduckmaster [ Mon Apr 30, 2012 3:46 pm ] |
When the motor is in the water your ok without a rev limiter it's when you hit something and the motor comes out the water is when you pray!! |
