gatortail question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=28891 |
Author: | Landry18 [ Mon Apr 30, 2012 7:58 pm ] |
Post subject: | gatortail question |
I was wondering if anyone knows why sometimes when i switch from start to forward on my GTR it kills. I know it is something stupid but i just don't know. I have looked in the search box and could not find the answer i was looking for. |
Author: | duckduckboom [ Mon Apr 30, 2012 7:58 pm ] |
Post subject: | Re: gatortail question |
Is your prop sitting in mud |
Author: | Landry18 [ Mon Apr 30, 2012 8:06 pm ] |
No, it does it mostly right when i launch the boat. Could my rpm's be to low. My friend said something about a tab that needs to be bent or something. No clue, it only happens for a liitle while then its fine. |
Author: | duckduckboom [ Mon Apr 30, 2012 8:07 pm ] |
Like when it is cold |
Author: | Landry18 [ Mon Apr 30, 2012 8:08 pm ] |
I mean Idle to low |
Author: | duckduckboom [ Mon Apr 30, 2012 8:09 pm ] |
1200 in neutral |
Author: | cb5331 [ Mon Apr 30, 2012 8:11 pm ] |
What does it idle at? Most stock motors should idle okay in the 12-1300 range in neutral and 1000-1100 in gear. Improperly set or leaking valves can cause some idle issues, but check and see what your rpm's are first. |
Author: | Landry18 [ Mon Apr 30, 2012 8:13 pm ] |
1500 neutral, and i will go from like 800 to 700 in gear |
Author: | Landry18 [ Mon Apr 30, 2012 8:15 pm ] |
I adjusted the idle yesterday and got it back to normal. I was just curious about the killing issue |
Author: | duckduckboom [ Mon Apr 30, 2012 8:15 pm ] |
Yeah sounds like you need to adjust some valves an see if that helps |
Author: | Landry18 [ Mon Apr 30, 2012 8:31 pm ] |
But would that aways occur if the valves were not sitting right. It only occurs right from the launch and my friend who has a GTR as well says it happens to his sometimes. |
Author: | bubba777 [ Mon Apr 30, 2012 10:38 pm ] |
mine is idle about 960 and 875 in water flip it in gear and run it like tou stole it but after you check your valves |
Author: | Team Camo [ Mon Apr 30, 2012 11:53 pm ] |
Most likely it's leaky or improperly adjusted valves. Set the valve lash to .005 & see if it gets any better. |
Author: | MaXXis85 [ Tue May 01, 2012 5:51 am ] |
Check valve lash. |
Author: | msm8281 [ Tue May 01, 2012 6:12 am ] |
