pro drive wont turn over
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=28966
Page 1 of 2
Author:  owen5 [ Thu May 03, 2012 6:36 pm ]
Post subject:  pro drive wont turn over
I was letting the engine idle to heat it up before I changed the oil. It was running smooth and then it just died. Almost like it flooded itself. Let if stand for a while and try to crank it back up and nothing. Checked the fuel line, fuel pump, carb, vent on tank, everything that I can think of and can't get it to turn over. Tried starting fluid and it will turn over but wont run like the engine isn't getting fuel. Any ways, I need some advise on what to look for next. Any suggestions?
Author:  Will [ Thu May 03, 2012 6:39 pm ]
Post subject:  Re: pro drive wont turn over
Gas in the tank?
Author:  PaleoHuntr [ Thu May 03, 2012 6:44 pm ]
Pull the fuel line going from the pump to the carb and turn it over, this will let you know if you are getting fuel. have you tried squeezing the throttle while cranking?
Author:  Woodiebuster [ Thu May 03, 2012 6:53 pm ]
Is your kill switch hooked up correctly?
Are you getting spark?
Author:  lastchance [ Thu May 03, 2012 6:59 pm ]
It is not a good thing to feed these, or any engine crack!!!!!
Author:  richard nagon [ Thu May 03, 2012 7:04 pm ]
please don't do what paleo told u to do.one spark and u will be buying a new engine. garage. house.
Author:  craig [ Thu May 03, 2012 7:07 pm ]
Author:  Woodiebuster [ Thu May 03, 2012 7:12 pm ]
I think yall are taking the wrong approach at it.
A engine that suddenly dies and won't even attemp to crank back up, even with starting fluid in the carb sounds like there is no spark in the cylinder.
CHECK THE KILLSWITCH then report back.
If that doesn't fix it, pull the plugs. If they reek of gas they are getting fuel, then put it in the boot, ground it against the motor and turn it over to look for spark.
Author:  PaleoHuntr [ Thu May 03, 2012 7:16 pm ]
Author:  richard nagon [ Thu May 03, 2012 7:16 pm ]
are u to put the gas in the boot or the spark plug in the boot. woodie ?
Author:  craig [ Thu May 03, 2012 7:19 pm ]
Author:  PaleoHuntr [ Thu May 03, 2012 7:21 pm ]
Is the end result not the same? I didn't tell him to keep cranking till his tank ran empty.
Author:  richard nagon [ Thu May 03, 2012 7:25 pm ]
paleo not everbody is as smart as u. so give the o.p the full story. like what craig said about u.your our what you our. a flucking tard. :shock:
Author:  cb5331 [ Thu May 03, 2012 7:28 pm ]
Author:  BayouRunner [ Thu May 03, 2012 7:31 pm ]
Really don't know anything about pro drives but does it have an oil pressure sensor? Pull that wire and see if she'll run.
Author:  richard nagon [ Thu May 03, 2012 7:31 pm ]
cb. a delta moment :lol:
Author:  cb5331 [ Thu May 03, 2012 7:32 pm ]
This is probably not what it is, but the only time I ever had an issue that was even remotely similar, it was the fuel solenoid on the carb.
Author:  craig [ Thu May 03, 2012 7:35 pm ]
Author:  cb5331 [ Thu May 03, 2012 7:36 pm ]
Pissed me the fuck off too, there is now a bolt in that hole. :lol:
Author:  craig [ Thu May 03, 2012 7:40 pm ]
Author:  POKER1 [ Thu May 03, 2012 7:52 pm ]
WTF will jacking with the fuel do for a motor that wont turn over?
Author:  craig [ Thu May 03, 2012 8:00 pm ]
Author:  cb5331 [ Thu May 03, 2012 8:10 pm ]
Author:  POKER1 [ Thu May 03, 2012 8:16 pm ]
Author:  duckduckboom [ Thu May 03, 2012 8:20 pm ]
If you don't hear a click when you turn your motor on(not start)fuel solenoid
Author:  POKER1 [ Thu May 03, 2012 8:24 pm ]
Author:  craig [ Thu May 03, 2012 8:35 pm ]
Author:  naj [ Thu May 03, 2012 9:51 pm ]
Author:  duckduckboom [ Thu May 03, 2012 10:02 pm ]
Author:  owen5 [ Fri May 04, 2012 11:40 am ]
the starter works and the engine is trying to start but it wont. I had it running and then the thing just idled down to where is just stopped and now nothing happens. It wont start but the starter works fine. The kill switch and clutch switch are working properly. The fuel line isn't blocked. The carb has fuel in the bowl. the spark plugs are firing. The vent is open on the tank. Just don't know. I think you all may be on to something with the fuel sensor. Any way of checking that?
Author:  craig [ Fri May 04, 2012 11:50 am ]
Where are you located?
Author:  owen5 [ Fri May 04, 2012 12:03 pm ]
South Carolina
Author:  cb5331 [ Fri May 04, 2012 12:20 pm ]
Take it off, cut the plunger off, and put it back in. Or put a short bolt in it instead. May not fix your problem, but you don't need it and it will eliminate it from the equation.
Author:  owen5 [ Fri May 04, 2012 3:03 pm ]
taking care of the fuel sensor, but it is working properly. next is the carb. going to clean it real good and hope this works.
Author:  duckduckboom [ Fri May 04, 2012 3:08 pm ]
Is your tach reading Rpms?
I didn't re read the whole thread*****
Author:  owen5 [ Fri May 04, 2012 4:11 pm ]
cant tell the rpm's. it doesn't run long enough to get to the other side of the engine.
Author:  duckduckboom [ Fri May 04, 2012 6:51 pm ]
If your tach doesn't respond you are not getting a spark
Author:  Woodiebuster [ Fri May 04, 2012 10:32 pm ]
If its getting spark you should be able to hold the starter down and see the tach reading a few hundred rpm
Author:  owen5 [ Mon May 07, 2012 5:15 pm ]
I want to thank everyone for the advise. I am back up and running. Thanks a lot!
Author:  POKER1 [ Mon May 07, 2012 5:25 pm ]
For future reference what was the issue.
Page 1 of 2 All times are UTC - 6 hours
