It is currently Sun Jun 22, 2025 1:55 am
Reply to topic  [ 8 posts ]
 stage 2 vs stage 3
Post stage 2 vs stage 3
Im almost completed building my heads, port polish, deck, shim sprngs, 3 angle valve seats, manley ss valves, billet push rods, and soon rockers. I already have evt carb and intake and should order exhaust this week. So now that im almost out of everything i can do without cracking the case open. First off the main thing i hear failing in the 35's is cams so im debating on if to do a cam. Next I will replace the connecting rod but im debating on piston setup. The main thing that seperates a stage 2 from a stage 3 is shaved pistons or extreme flat tops. Im leery of doing any work that cannot be returned to stock if performance parts become hard to find. flattop pistons require boring the block, cut pistons dont . What would be the diference in hp from a stage 2 to a stage 3? Also do bps pistons require a bored cylinder or are they stock fitted? Anyone running them and how do they perform?
17x54 custom CC with stage 3 GTR.
Sat Jun 27, 2009 1:20 pm
Post Re: stage 2 vs stage 3
u can get flat tops for de stock bore :mrgreen:
Sat Jun 27, 2009 4:03 pm
i doubt performance parts will become scarce, being that they were available before surface drives were, due to lawmower racing and go karts and shit
Sat Jun 27, 2009 4:47 pm
about $1000 and 2.5 mph on my big ass boat.
JD
Sun Jun 28, 2009 8:27 am
How about putting what you have together and seeing how it runs. :P
You may be very happy with the performance from heads, carb, and muffler.
Mon Jun 29, 2009 9:08 pm
Just waiting on the call to come get the heads then ill run it from there. I know when we do heads on automobiles we use a thred tracer to get all the dirt and gasket pieces out do yall do this on your mm's? any other precautionary measures yall can recommend for installation?
Mon Jun 29, 2009 10:02 pm
Tue Jun 30, 2009 6:41 am
Tue Jun 30, 2009 7:08 am
Users browsing this forum: No registered users and 161 guests
cron
