It is currently Wed Jul 16, 2025 8:37 am
Reply to topic  [ 16 posts ]
 Motor Seize Help????
Post Motor Seize Help????
I have a 35 hp Go Devil SD. I had to replace my crankcase cover as my cover gear had broke. I have replaced the gasket a couple of times so I have become adept at taking everything apart and putting it back together. Well, this evening I put the new crankcase cover on and assembled everything like in the past. Started the engine and it ran well for about 30 seconds and then the motor seized up and I can't get the cranckcase cover off to save my life as it won't come off!! Any input would be helpful!
Thanks,
Tim
Tue May 08, 2012 8:41 pm
Post Re: Motor Seize Help????
Did you have oil in the engine?
Tue May 08, 2012 9:15 pm
Tue May 08, 2012 9:47 pm
Tue May 08, 2012 9:48 pm
Yes I had oil in the engine. It ran fine like I said for about 30 seconds or so and then seized up and I can't get the crankcase cover off to save my life.
Tim
Wed May 09, 2012 4:45 am
can you turn the prop by hand? Turn it opposite of the motor rotation, and see if that will allow you to get the cover off.
Wed May 09, 2012 6:04 am
I cannot turn the prop at all. My neighbor runs a small engine repair shop and is coming over this evening to look at it for me. I will post the results.
Tim
Wed May 09, 2012 7:39 am
One other aspect that I forgot to post least night as I was a little pissed is that when I drained the oil before trying to remove the crankcase cover, the oil looked like coffee with cream which isn't good at all as it was brand new synthetic oil that I had put in before cranking it over. I keep it in my garage and have not run it since last January.
Tim
Wed May 09, 2012 7:41 am
That was probably just the mixture of the 2 different oils.
Was it a swirled ice cream look?
Wed May 09, 2012 7:44 am
Yes it was a swirl color.
Wed May 09, 2012 9:36 am
can u turn the prop opposite at all? usually if u can turn it a lil bit u cna get it off, kinda like when a steering wheel is locked
Wed May 09, 2012 1:57 pm
I cannot even budge the prop as it is locked like a drum.
Wed May 09, 2012 4:16 pm
How tight did you have the belt tension?
Wed May 09, 2012 4:24 pm
I have the belt tension gauge that I got from GD and tightened it up to the correct tension like always.
Thu May 10, 2012 5:36 am
Loosen belt could have seized pully or lower unit if not remove plugs and front cover and put socket and breaker bar and try to bump it back and forth.
- Mark Twain
Thu May 10, 2012 6:08 am
dude that sucks..
Fri May 11, 2012 12:49 am
Users browsing this forum: No registered users and 55 guests
