head surface/valve seal? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29062 |
Author: | mizzippi jb [ Mon May 07, 2012 4:52 pm ] |
Post subject: | head surface/valve seal? |
when you get a set of heads (like BPS Iron Mtn.) heads, how good is the seal supposed to be between valve and head surface out of the box? If you take them out of the package, is it ok to see light where it seals if you hold it up to a light? Not an issue for me, just curious. |
Author: | dfou [ Mon May 07, 2012 5:01 pm ] |
Between the valve and the valve seat? If so you should not see any light |
Author: | mizzippi jb [ Mon May 07, 2012 5:04 pm ] |
Post subject: | Re: head surface/valve seal? |
Author: | craig [ Mon May 07, 2012 5:26 pm ] |
Send them back and demand a refund ASAP!! Call Calen's Engine Service and get a set through him. I've seen and heard of SEVERAL different instances as of late describing the very thing you're experiencing. Apparently BPS is installing valves without performing a proper valve job/seal all the while charging the customer as though it was actually done. |
Author: | dfou [ Mon May 07, 2012 5:33 pm ] |
Cody at SETX sells a quality head as well |
Author: | OwenDickeson [ Mon May 07, 2012 6:02 pm ] |
Author: | dfou [ Mon May 07, 2012 6:10 pm ] |
Author: | take'emgator [ Mon May 07, 2012 7:47 pm ] |
Like mentioned before send them back, refund or whatever but don't install. Have you thought about just doing a head job on your stock heads, you can get the same performance if not better. Depending on what you want. Call cody at SETX and pick his mind he can tell you anything and everything you want to know about heads. |
Author: | mizzippi jb [ Tue May 08, 2012 7:45 am ] |
like stated in the original post, I ain't having this issue. |
Author: | deadbird8 [ Tue May 08, 2012 3:11 pm ] |
Light means leaking valves. |
Author: | deadbird8 [ Tue May 08, 2012 3:13 pm ] |
Author: | BoatDR [ Tue May 08, 2012 4:30 pm ] |
Author: | BoatDR [ Tue May 08, 2012 4:32 pm ] |
Author: | craig [ Tue May 08, 2012 4:49 pm ] |
Author: | duckduckboom [ Tue May 08, 2012 4:51 pm ] |
Author: | caddobrook [ Tue May 08, 2012 5:24 pm ] |
Before everyone gets too far afield on this one.. Please note that the original poster said IF!!! Not that he was actually having or had that problem.... He only used BPS as an example (not sure why and not really fair to B P S or any other company as you can see how the question then became he was having the problem). This was not a "real" issue and he even later posted that he was not having the issue... I guess he was just seeking information "in case".... |
Author: | take'emgator [ Tue May 08, 2012 5:32 pm ] |
Just read it again sorry for my post! |
Author: | mizzippi jb [ Tue May 08, 2012 6:26 pm ] |
Author: | med [ Tue May 08, 2012 6:27 pm ] |
You're just trying to get shit started ![]() |
Author: | mizzippi jb [ Tue May 08, 2012 6:30 pm ] |
looks like I did a damn fine job. Can't you read the sarcasm and prodding in the original post? ![]() |
Author: | PaleoHuntr [ Tue May 08, 2012 8:50 pm ] |
![]() ![]() ![]() craig's so desperate to sling shit on MB products that he can't even read a full post, what a tool ![]() |
Author: | duckduckboom [ Tue May 08, 2012 8:56 pm ] |
Actually I believe you entered this topic to late. I believe orginal poster changed his post. Not to mention Owen actually had a set of thosle leaking valves |
Author: | craig [ Tue May 08, 2012 9:11 pm ] |
Author: | PaleoHuntr [ Tue May 08, 2012 9:16 pm ] |
Author: | mizzippi jb [ Wed May 09, 2012 4:27 am ] |
Author: | duckduckboom [ Wed May 09, 2012 6:36 am ] |
Author: | craig [ Wed May 09, 2012 6:48 am ] |
Author: | deadbird8 [ Wed May 09, 2012 8:34 pm ] |
Author: | deadbird8 [ Thu May 10, 2012 6:11 am ] |
