It is currently Thu Jul 17, 2025 12:14 am
Reply to topic  [ 9 posts ]
 Round 2 with Pro Drive
Post Round 2 with Pro Drive
Finally got my engine up and running after rebuilding the carb. I was out running it a couple days ago and after about 5-7 minutes of running around 3900 RPM it would surge. The rpms would drop down to 3400 and surge between that and 3600. I reached down and pumped the bulb and it would go back to running properly. The bulb was about 1/2 to 3/4 full. Is this the indication that the fuel pump is starting to go out? Thanks Owen
Sat May 12, 2012 8:07 am
Post Re: Round 2 with Pro Drive
Is your motor a CDI?
Sat May 12, 2012 8:52 am
Sounds like u have a leak in your fuel line. But it also could be the fuel pump.
18'x54"CC Hanko/ 36PD
Sat May 12, 2012 2:11 pm
Do you have quick connects on the fuel line?
18x48 Charles Leonard / 36PD
Sat May 12, 2012 2:50 pm
Could be vapor lock, leak in the fuel line, or a faulty fuel pump.
Sat May 12, 2012 3:03 pm
thanks for the input. I have a 2007 prodrive. Not 100% if it is CDI. I checked the fuel line and and the bulb, can't find a hole or leak in the fuel line. I guess I might replace the fuel pump. Should the bulb be full of fuel and all times?
Tue May 15, 2012 9:50 am
Those cam driven fuel pumps suck. Do a search on here and look into puttin in an additional fuel pump, or call prodrive and ask what they recommend for a fuel pump.
Tue May 15, 2012 10:21 am
Actually, just call PD. Their customer service is second to none, they will fix you up.
Tue May 15, 2012 10:23 am
go to your local auto parts and get the Mr gasket 2-3lbs fuel pump
http://www.oreillyauto.com/site/c/detai ... &ppt=C0025
I gave up mud motors
Tue May 15, 2012 5:28 pm
Users browsing this forum: No registered users and 66 guests
