mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 head surface/valve seal?
when you get a set of heads (like BPS Iron Mtn.) heads, how good is the seal supposed to be between valve and head surface out of the box? If you take them out of the package, is it ok to see light where it seals if you hold it up to a light? Not an issue for me, just curious.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Mon May 07, 2012 4:52 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
Between the valve and the valve seat? If so you should not see any light
Mon May 07, 2012 5:01 pm |
mizzippi jb
 Re: head surface/valve seal?
Mon May 07, 2012 5:04 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
Send them back and demand a refund ASAP!!
Call Calen's Engine Service and get a set through him.
I've seen and heard of SEVERAL different instances as of late describing the very thing you're experiencing.
Apparently BPS is installing valves without performing a proper valve job/seal all the while charging the customer as though it was actually done.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Mon May 07, 2012 5:26 pm |
dfou
Cody at SETX sells a quality head as well
Mon May 07, 2012 5:33 pm |
OwenDickeson
Mon May 07, 2012 6:02 pm |
dfou
Mon May 07, 2012 6:10 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Like mentioned before send them back, refund or whatever but don't install. Have you thought about just doing a head job on your stock heads, you can get the same performance if not better. Depending on what you want. Call cody at SETX and pick his mind he can tell you anything and everything you want to know about heads.
Mon May 07, 2012 7:47 pm |
mizzippi jb
like stated in the original post, I ain't having this issue.
Tue May 08, 2012 7:45 am |
deadbird8
Light means leaking valves.
Tue May 08, 2012 3:11 pm |
deadbird8
Tue May 08, 2012 3:13 pm |
BoatDR
Tue May 08, 2012 4:30 pm |
BoatDR
Tue May 08, 2012 4:32 pm |
craig
Tue May 08, 2012 4:49 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
_________________ You have your whole life to be an idiot, take a day off!
Tue May 08, 2012 4:51 pm |
caddobrook
Before everyone gets too far afield on this one..
Please note that the original poster said IF!!! Not that he was actually having or had that problem.... He only used BPS as an example (not sure why and not really fair to B P S or any other company as you can see how the question then became he was having the problem).
This was not a "real" issue and he even later posted that he was not having the issue... I guess he was just seeking information "in case"....
Tue May 08, 2012 5:24 pm |
take'emgator
Just read it again sorry for my post!
Tue May 08, 2012 5:32 pm |
mizzippi jb
Tue May 08, 2012 6:26 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
You're just trying to get shit started
_________________ 1850 & 36pd
Tue May 08, 2012 6:27 pm |
mizzippi jb
looks like I did a damn fine job. Can't you read the sarcasm and prodding in the original post?
Tue May 08, 2012 6:30 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Tue May 08, 2012 8:50 pm |
duckduckboom
Actually I believe you entered this topic to late. I believe orginal poster changed his post. Not to mention Owen actually had a set of thosle leaking valves
Tue May 08, 2012 8:56 pm |
craig
Tue May 08, 2012 9:11 pm |
PaleoHuntr
Tue May 08, 2012 9:16 pm |
mizzippi jb
Wed May 09, 2012 4:27 am |
duckduckboom
Wed May 09, 2012 6:36 am |
craig
Wed May 09, 2012 6:48 am |
deadbird8
Wed May 09, 2012 8:34 pm |
deadbird8
Thu May 10, 2012 6:11 am |
