Blue flame http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29165 |
Author: | QuackAndChatter [ Fri May 11, 2012 8:10 pm ] |
Post subject: | Blue flame |
I did a search but couldnt find anything out. When i run at night my crossover is putting out a blue flame. Is this normal or what should i fix? |
Author: | cb5331 [ Fri May 11, 2012 9:17 pm ] |
Post subject: | Re: Blue flame |
Only at night? |
Author: | richard nagon [ Fri May 11, 2012 9:26 pm ] |
what diff would that make. u on crack. ![]() |
Author: | cb5331 [ Fri May 11, 2012 9:33 pm ] |
Just making small talk. ![]() |
Author: | richard nagon [ Fri May 11, 2012 9:55 pm ] |
quack i first would ck the plugs see if they are a choc. brown. a blue flame could be a sign of a rich fuel issue. ck ur choke. is ur carb clean. float setting. is ur jetting to rich. also a blue flame can be a sign a valve issue reset ur valves and do a leak down test. a bad exhaust leak. that seems to show up at a wide open throttle to a closed throttle more so than a constant wot. if all else fails do as pod and camo do put in $10.00 plus spark plugs. ![]() |
