Kja0792
 Setx perfomance heads
[list=][/list] looking at buying a set of IM heads and ran across setx and saw they do a performances head as well just wondering if anyone has them and how tgey do or should i stick with the iron mountains.
Sun May 13, 2012 7:06 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
 Re: Setx perfomance heads
Haven't done my motor but I know several people that were really pleased w/ Cody's head work. Just give this a few minutes you will get some more answers.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Sun May 13, 2012 7:41 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Mine are done by Cody as well as several others in our area and on this site. He does some nice work. Really pays atttention to detail. Always makes sure they are 100% before they go out!
Sun May 13, 2012 7:47 pm |
Kja0792
What is the difference betwern his and IM?? I didnt see any info about them accept obvious things
Sun May 13, 2012 7:51 pm |
take'emgator
Port work is the main difference. The way he cuts his valves, depending on what engine mods you have determines what he does to your heads. Believe it or not there are different ways you can set up your heads.
Do you have a performance Muffler, if your going to be flowing more air you'll need a better way for it to get out. More air, more exhaust, the better your engine will run and perform
Sun May 13, 2012 7:55 pm |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
Put it this way. I bought IM heads and had Cody redo mine.
Sun May 13, 2012 9:34 pm |
Will
From what I understand, IM heads are built on the same specs and each one is the same, basically an "off the shelf" aftermarket head. Someone fill free to correct me if I'm wrong on that.
SETX heads are "custom" built specifically for your set up to get the most out of it.
If you're only moderatly building your motor, the IM heads may move too much air for your engine to perform at it's best. A certain air volume at the correct velocity is what you want for peak performance along with a good set up on the valves. This is where the "custom" heads shine.
Mon May 14, 2012 5:20 am |
WestEndAngler
MMT Moderator
Cody did my heads as well.
Mon May 14, 2012 1:33 pm |
lngtail24
Joined: Tue Sep 22, 2009 7:13 pm Posts: 210 Location: Mobile, AL
Mon May 14, 2012 3:59 pm |
Kja0792
Mon May 14, 2012 5:20 pm |
DuckHunterF250
Joined: Tue Jun 29, 2010 8:32 pm Posts: 1801 Location: atlanta texas
Just go with cody's heads and do it right the first time.
_________________ 1854 DeadFowl custom boat 35 GTR "The bitterness of poor quality remains long after the sweetness of low price is forgotten."
Mon May 14, 2012 5:30 pm |
cb5331
Just give Cody a call. I seem to remember him telling me he does all his heads the same no matter what other work is being done. Either way, he can explain what he does better than a bunch of folks that drop their motors off there for him to work on.
Mon May 14, 2012 5:32 pm |
take'emgator
What these guys said! Call the number in my sig
Mon May 14, 2012 5:44 pm |
Kja0792
yea ill give him a call because i want to port and polish my intake and want all the port work to match each other of the heads and intake do yalll know if he does the port on intakes
Mon May 14, 2012 6:06 pm |
DuckHunterF250
yes he does. cody can do whatever you need done
Mon May 14, 2012 6:08 pm |
Kja0792
thanks for the info guys
Mon May 14, 2012 6:36 pm |
richard nagon
to the prostaffers. can u please explain by cutting ur valves not grinding. can unleash the power that u take about. i thought the power gain would be in the i think its called the combustion chamber. i like the op want to know. i don't know that much about these heads. but is there enough seat surface to do more than a three angle job. ? i would think that after prolonged hrs of use. a 4 or 5 angle valve job would fail. ? just how much material do u take out of the head u know the combustion chamber. can u take to much out or not.? i've heard that a flow bench is needed to aid in the job. i see u port the upper intake do u do anything to the lower intake.? what do they mean by decking a head. ? will that give me even more power. will a cam profile-deck height-compression ratio-exhaust come into play or not. i anxiously await for ur help. thanks.
_________________ JUST ANOTHER FARMER ON WELFARE
Mon May 14, 2012 6:49 pm |
take'emgator
Mon May 14, 2012 7:57 pm |
DuckHunterF250
nagging do you even have a boat? or are you still riding around on a lawn mower?
Mon May 14, 2012 8:03 pm |
take'emgator
I know my rights i know my rights!!!!!lmao
Mon May 14, 2012 8:07 pm |
lucecr
_________________ InstaGator 16.5' x 46" 25efi GTR. Running 30+ SOLD!!!!
dillakilla12 wrote:
I just passed out bc of the blood rush to my penis! Where the fugg can I get a transom like that!?
Mon May 14, 2012 8:21 pm |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
I can't wait to get mine back from Cody. Seems like a pretty damn good mechanic from what I've heard and seen.
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Mon May 14, 2012 8:32 pm |
richard nagon
and out from under the desk cums the midget and his tag along. with bibs on and juice dripping from the chin. epic fail on a 3 verses 5 angle valve job. u doing a 5 angle on the intake.? these chambers will only flow so much. but u would have no freaking idea with out a bench. how do u have a reference point with out one. how far is to far. again a epic fail. a man doing porting work with out a flow bench is a man that is hoping for the best. hey but good luck. i'll keep my roosters. sounds like u have a fetish with farm animals.
Mon May 14, 2012 9:35 pm |
take'emgator
Mon May 14, 2012 11:37 pm |
txmudcutter
Joined: Mon Jan 30, 2012 9:08 am Posts: 2307 Location: Nederland, TX (SETX)
What kind of douche gets on her asking questions then comes back and acts like they wrote the book on heads. Wtf
Tue May 15, 2012 7:42 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Tue May 15, 2012 7:55 am |
Will
douchebag disease - To cure douchebag-iness, apply fist to face of douchebag every once in a while (usually when he tries to act out). After a while it may or may not disappear. If symptoms continue, resort to more violent and dramatic measures.
Tue May 15, 2012 8:21 am |
txmudcutter
^lmfao is that approved by the FDA lol
Tue May 15, 2012 9:14 am |
Kja0792
Never knew i could stur up so much shit but cody i will be giving u a call to ask my list of questions
Tue May 15, 2012 11:29 am |
Robn1020
Tue May 15, 2012 12:20 pm |
CLICKSTER
It runs so fast cause of his crappy head work! Just playing! My whole engine is worked over by Cody and that little bitch flys!
Tue May 15, 2012 12:22 pm |
txmudcutter
"Never knew i could stur up so much shit but cody i will be giving u a call to ask my list of questions"
Well when you make a thread asking about headwork then start telling someone who's done alot of peoples motor work that they don't know what they're talking about your gonna ruffle some feathers just fyi
Tue May 15, 2012 1:34 pm |
cb5331
You could ask about the weather and we'd find a way to argue about it....
BTW, the sky is blue. What now bitches?
Tue May 15, 2012 1:40 pm |
PaleoHuntr
Joined: Mon Feb 21, 2011 5:21 pm Posts: 1800 Location: Idaho Falls, ID
Technically the "sky" is colorless, it only appears blue because atmospheric gases and dust particles reflect the blue wavelength of light...
_________________ 1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Tue May 15, 2012 1:45 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
_________________ 35 GTR - 1754 Extreme
Tue May 15, 2012 1:46 pm |
CJB
Dammit Paleo
Tue May 15, 2012 1:47 pm |
PaleoHuntr
 gotta be quick!
cb5331
Bullshit, just went and checked...its blue. Fuck all of you, I'm right, you're wrong. Suck it!
Tue May 15, 2012 1:54 pm |
SCmudder7071
_________________ 1754 Extreme/LAProp Stage 2 GTR
Tue May 15, 2012 6:15 pm |
Kja0792
I would hope not but insight is good some people have to be a holes n start stuff
Tue May 15, 2012 7:44 pm |
