It is currently Mon Jul 14, 2025 3:47 pm
Reply to topic  [ 7 posts ]
 slight rpm loss
Post slight rpm loss
I got my original problem fixed (sputtering, only running around 3500 rpms can be seen herehttp://www.mudmotortalk.com/mmt_v2/ ... =3&t=28475 ). spark plugs appeared to be the culprit, and it ran better upon taking it out. problem now is a slight (appx 300) rpm loss. could only run around 4150-4250, normally am running somewhere around 4400-4500. I am going to check the lash tonight or tomorrow to double check i set it correctly. could the lash being set too tight or loose cause this rpm loss?
Gator Trax 1644 HD pushed by a screamin' MB Mini 35
Thu May 17, 2012 8:26 am
Post Re: slight rpm loss
Yep check valve lash. Valves too tight can keep the valve Open off the seat, and too loose wont open them far enough...
Thu May 17, 2012 9:58 am
make sure your head gaskets aren't leaking as well, Joel. That could cause a slight rpm loss if the leak is minimal.
HOTSAUCE170 wrote:
Thu May 17, 2012 10:10 am
have a hunch it's the valves. Jim i checked when i was home for lunch and no obvious leaks. those gaskets got a good bit of attention when we reinstalled the heads.
Thu May 17, 2012 10:43 am
got in the valves last night. one of the exhaust valves was way loose. hopefully that'll curtail my problem.
Thu May 24, 2012 6:06 am
i hear ya! My valves were rattling pretty good after a few hrs. with the new heads. So bad the motor would sputter some after the switch was turned off. Just reset em after the ride last weekend. You finished with rugby season? Ready to put a ride or 2 together?
Thu May 24, 2012 6:44 am
Thu May 24, 2012 7:02 am
Users browsing this forum: No registered users and 108 guests
