It is currently Thu Jul 17, 2025 12:24 am
Reply to topic  [ 20 posts ]
 Grinding sound
Post Grinding sound
I can't tell if it's from my new belt or my transmission or clutch but there's a kinda grinding sound. Sounds like something with the pulleys but no clue. Havent run it in 2 weeks so idk I'm I'm just hearing something. Any suggestions this? its a 35 GTR
1754 GTB / 35 GTR
Fri May 18, 2012 3:21 pm
Post Re: Grinding sound
check and see if your prop is tight! Just did this to mine yesterday, sounds like its coming from the lower unit, but it was just the prop
Fri May 18, 2012 3:22 pm
If hasn't been run in a while, could just be surface rust between clutch & clutch plate.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri May 18, 2012 3:47 pm
Props tight it seems to be coming from the upper pulley or somewhere around there. I mean it's in garage storage
1754 GTB / 35 GTR
Fri May 18, 2012 4:36 pm
Does this mean you aren't going to the lake tomorrow? I know nothing about a GTR but from bike experience, can the belt be too tight?
Fri May 18, 2012 6:17 pm
Make sure brake pads are not rubbing first. Sounds like either that or the bearings in your clutch. With the engine off and in neutral, turn the prop by hand and see if you can pinpoint where the noise is coming from.
Fri May 18, 2012 6:40 pm
Sale it and put your order in for a MB Sport V. :lol:
Casey
Fri May 18, 2012 6:55 pm
hope its not your transmission,....better check the fluid :o
HOTSAUCE170 wrote:
Fri May 18, 2012 7:14 pm
Fri May 18, 2012 7:41 pm
check the original post....he names it as a possible source of the grinding. :D
Fri May 18, 2012 7:47 pm
Casey
Fri May 18, 2012 7:51 pm
Fri May 18, 2012 7:56 pm
Bleed your brake calipers, if you have air in your brake lines it could cause the piston to not retract and grind/rub. Either way, the grinding cant be good, whether it is from your brakes or elsewhere on your lower unit! Warranty still good?
Fri May 18, 2012 11:57 pm
Sounds like bearings in the clutch. All fluids good just change oil in tranny and breaks good too
1754 GTB / 35 GTR
Sat May 19, 2012 1:16 am
Have you pulled the cover off to look yet?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat May 19, 2012 6:27 am
Casey
Sat May 19, 2012 6:43 am
I tell ya idk if I'm just hearing something or what but with engine of and the cover...duh... It's like right near the belt or clutch goin to get some other opinions today.
1754 GTB / 35 GTR
Sat May 19, 2012 10:33 am
Casey
Sat May 19, 2012 10:43 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat May 19, 2012 5:35 pm
I think it's just the new belt
1754 GTB / 35 GTR
Sat May 19, 2012 9:03 pm
Users browsing this forum: No registered users and 75 guests
