NFW
Joined: Tue Jul 13, 2010 5:45 pm Posts: 625 Location: North Florida / Jackson, MS
 Grinding sound
I can't tell if it's from my new belt or my transmission or clutch but there's a kinda grinding sound. Sounds like something with the pulleys but no clue. Havent run it in 2 weeks so idk I'm I'm just hearing something. Any suggestions this? its a 35 GTR
_________________ 1754 GTB / 35 GTR
Fri May 18, 2012 3:21 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: Grinding sound
check and see if your prop is tight! Just did this to mine yesterday, sounds like its coming from the lower unit, but it was just the prop
Fri May 18, 2012 3:22 pm |
Team Camo
 Re: Grinding sound
If hasn't been run in a while, could just be surface rust between clutch & clutch plate.
Fri May 18, 2012 3:47 pm |
NFW
 Re: Grinding sound
Props tight it seems to be coming from the upper pulley or somewhere around there. I mean it's in garage storage
Fri May 18, 2012 4:36 pm |
Will
 Re: Grinding sound
Does this mean you aren't going to the lake tomorrow? I know nothing about a GTR but from bike experience, can the belt be too tight?
Fri May 18, 2012 6:17 pm |
quackconsumer
 Re: Grinding sound
Make sure brake pads are not rubbing first. Sounds like either that or the bearings in your clutch. With the engine off and in neutral, turn the prop by hand and see if you can pinpoint where the noise is coming from.
Fri May 18, 2012 6:40 pm |
po po mud duck
Joined: Wed Jun 30, 2010 7:13 am Posts: 317 Location: Port Arthur TX.
 Re: Grinding sound
Sale it and put your order in for a MB Sport V.
_________________ Casey
Fri May 18, 2012 6:55 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Grinding sound
hope its not your transmission,....better check the fluid
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Fri May 18, 2012 7:14 pm |
quackconsumer
 Re: Grinding sound
Fri May 18, 2012 7:41 pm |
mizzippi jb
 Re: Grinding sound
check the original post....he names it as a possible source of the grinding.
Fri May 18, 2012 7:47 pm |
po po mud duck
 Re: Grinding sound
Fri May 18, 2012 7:51 pm |
quackconsumer
 Re: Grinding sound
Fri May 18, 2012 7:56 pm |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
 Re: Grinding sound
Bleed your brake calipers, if you have air in your brake lines it could cause the piston to not retract and grind/rub. Either way, the grinding cant be good, whether it is from your brakes or elsewhere on your lower unit! Warranty still good?
Fri May 18, 2012 11:57 pm |
NFW
 Re: Grinding sound
Sounds like bearings in the clutch. All fluids good just change oil in tranny and breaks good too
Sat May 19, 2012 1:16 am |
Team Camo
 Re: Grinding sound
Have you pulled the cover off to look yet?
Sat May 19, 2012 6:27 am |
po po mud duck
 Re: Grinding sound
Sat May 19, 2012 6:43 am |
NFW
 Re: Grinding sound
I tell ya idk if I'm just hearing something or what but with engine of and the cover...duh... It's like right near the belt or clutch goin to get some other opinions today.
Sat May 19, 2012 10:33 am |
po po mud duck
 Re: Grinding sound
Sat May 19, 2012 10:43 am |
Team Camo
 Re: Grinding sound
Sat May 19, 2012 5:35 pm |
NFW
 Re: Grinding sound
I think it's just the new belt
Sat May 19, 2012 9:03 pm |
