Grinding sound
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=29300
Author:  NFW [ Fri May 18, 2012 3:21 pm ]
Post subject:  Grinding sound
I can't tell if it's from my new belt or my transmission or clutch but there's a kinda grinding sound. Sounds like something with the pulleys but no clue. Havent run it in 2 weeks so idk I'm I'm just hearing something. Any suggestions this? its a 35 GTR
Author:  take'emgator [ Fri May 18, 2012 3:22 pm ]
Post subject:  Re: Grinding sound
check and see if your prop is tight! Just did this to mine yesterday, sounds like its coming from the lower unit, but it was just the prop
Author:  Team Camo [ Fri May 18, 2012 3:47 pm ]
If hasn't been run in a while, could just be surface rust between clutch & clutch plate.
Author:  NFW [ Fri May 18, 2012 4:36 pm ]
Props tight it seems to be coming from the upper pulley or somewhere around there. I mean it's in garage storage
Author:  Will [ Fri May 18, 2012 6:17 pm ]
Does this mean you aren't going to the lake tomorrow? I know nothing about a GTR but from bike experience, can the belt be too tight?
Author:  quackconsumer [ Fri May 18, 2012 6:40 pm ]
Make sure brake pads are not rubbing first. Sounds like either that or the bearings in your clutch. With the engine off and in neutral, turn the prop by hand and see if you can pinpoint where the noise is coming from.
Author:  po po mud duck [ Fri May 18, 2012 6:55 pm ]
Sale it and put your order in for a MB Sport V. :lol:
Author:  mizzippi jb [ Fri May 18, 2012 7:14 pm ]
hope its not your transmission,....better check the fluid :o
Author:  quackconsumer [ Fri May 18, 2012 7:41 pm ]
Author:  mizzippi jb [ Fri May 18, 2012 7:47 pm ]
check the original post....he names it as a possible source of the grinding. :D
Author:  po po mud duck [ Fri May 18, 2012 7:51 pm ]
Author:  quackconsumer [ Fri May 18, 2012 7:56 pm ]
Author:  vertical_edge_800 [ Fri May 18, 2012 11:57 pm ]
Bleed your brake calipers, if you have air in your brake lines it could cause the piston to not retract and grind/rub. Either way, the grinding cant be good, whether it is from your brakes or elsewhere on your lower unit! Warranty still good?
Author:  NFW [ Sat May 19, 2012 1:16 am ]
Sounds like bearings in the clutch. All fluids good just change oil in tranny and breaks good too
Author:  Team Camo [ Sat May 19, 2012 6:27 am ]
Have you pulled the cover off to look yet?
Author:  po po mud duck [ Sat May 19, 2012 6:43 am ]
Author:  NFW [ Sat May 19, 2012 10:33 am ]
I tell ya idk if I'm just hearing something or what but with engine of and the cover...duh... It's like right near the belt or clutch goin to get some other opinions today.
Author:  po po mud duck [ Sat May 19, 2012 10:43 am ]
Author:  Team Camo [ Sat May 19, 2012 5:35 pm ]
Author:  NFW [ Sat May 19, 2012 9:03 pm ]
I think it's just the new belt
