It is currently Tue Jul 15, 2025 6:30 am
Reply to topic  [ 17 posts ]
 Mikuni carb acting up
Post Mikuni carb acting up
Seem it starts and runs fine for about 5 mins or less then starves for fuel. Carb makes a sucking sound when throttle up from idle and dies if throttle not feathered back. Seems after it sits for a while it will crank up and run fine. My guess is water in fuel, or air lock? What are your expert opinions. Currently won't start. Will wait a few and try again shortly. On trailer so no emergency.
Tue May 15, 2012 5:52 pm
Post Re: Mikuni carb acting up
Fuel pumps working fine. But my gas smells more like alcohol. I think I have water in my tank. Will flush it out well and try again later. Removed air filter and there was small pool of water in intak openimg.
Tue May 15, 2012 6:12 pm
Definitely water in fuel. I drained fule line with electric fuel pump. Fuelnin line was murky looking. Should I run good fuel through engine quickly to avoid internal corrosion? Or wait till tomorrow when I have the time?
Tue May 15, 2012 6:36 pm
For future reference you can shine a flashlight in your tank at night and if you see what looks like diamonds in the bottom that would be water. Sounds like another ethanol casualty!
Tue May 15, 2012 8:22 pm
I would take the bowl cap off bottom of carb & pump new, clean fuel into carb & let some wash right on thru. Put the cap back on & run for a few minutes. Good luck. This gas these days sucks ass.
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Tue May 15, 2012 8:27 pm
I keep marine grade Stabil in my tank and it's the real deal. Try it Mr. Guidry.
Tue May 15, 2012 8:29 pm
^^^ X2!!! ^^^
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 15, 2012 10:10 pm
What Owen said plus add a water/fuel separator. Not expensive and easy to install. Had to do it on both the boats I have with merc outboards. Saves a lot of headaches.
InstaGator 16.5' x 46" 25efi GTR. Running 30+ SOLD!!!!
dillakilla12 wrote:
I just passed out bc of the blood rush to my penis! Where the fugg can I get a transom like that!?
Cleaned out gas tank. Washed out with gas treatment. Let dry overnight. Filled with new fuel. Changed in line filter. Yesterday, I had drained all the gas lines.
Started first crank today and running very nicely.
The gas I drained from the tank was very opaque/murky looking...dirty as hell. The gas and water had separated in the tank with the bad stuff at the bottom. Lesson learned. I'm in the market for fuel/water separator/filter.
Now, what to do with 5 gallons of bad gas?
Fri May 18, 2012 11:06 am
Over here the parish dump will accept hazardous waste from residents (tires, batteries, oil, gas, etc) but only in small quantites.
Fri May 18, 2012 11:18 am
Fire ant mounds
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri May 18, 2012 11:22 am
Fri May 18, 2012 11:45 am
:lol: I don't know either, but i bet it ain't cheap
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri May 18, 2012 11:59 am
Give it to a GD owner since they were invented before the fuel filter :lol:
Fri May 18, 2012 1:00 pm
get one of those fancy funnels with the water screen in it and put it in your car or something. If my boat gas sits too long I just pour it into my gas guzzler 4.7L V8 jeep and its gone in no time (unfortunately).
Sat May 19, 2012 12:08 am
That little bit of gas in your vehicle will have not effet.
1754 Xtreme 35 GTR Stage 1
Sat May 19, 2012 7:07 am
Mon May 21, 2012 6:15 am
Users browsing this forum: No registered users and 114 guests
