Bubby83
 Motor Running Rich After Valve adjustment
I just set my valves on my BD 4500 the other day. they were way out. .008 on the intake and .015 on the exhaust. I set them all to .006. Since the adjustment I have notice that my motor seams to be running rich. Plugs are black, and if I run for a while, shut it down, then try and start it a couple minutes later, it is hard to start. Is this a common thing? how would I go about adjusting my carb to lean it out a bit?
Tue May 22, 2012 7:35 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: Motor Running Rich After Valve adjustment
Does TDC mean anything to you?
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Tue May 22, 2012 8:17 pm |
richard nagon
does burnt fingers mean anything to u. dguidry  bubby83 try setting ur valve lash on the back side of the lobes it is in my opionion a better way of setting lash do a search.
_________________ JUST ANOTHER FARMER ON WELFARE
Tue May 22, 2012 8:41 pm |
dguidry
Tue May 22, 2012 8:47 pm |
Bubby83
Wed May 23, 2012 11:19 am |
dguidry
Wed May 23, 2012 12:33 pm |
cb5331
What was wrong before you "fixed" it?
Wed May 23, 2012 1:15 pm |
Woodiebuster
running to lean
Wed May 23, 2012 2:26 pm |
Bubby83
Wed May 23, 2012 5:08 pm |
cb5331
Yeah, I saw where you posted that but the motor wasn't running like shit before you messed with it, right? What else has changed?
Wed May 23, 2012 5:17 pm |
Bubby83
no more valve clatter.....
Wed May 23, 2012 6:35 pm |
cj
if you set your valve lash to exact specs. i would think that your rich problem was already present.you might be just noticing it after the fact. i would rejet your carb install new plugs and run a test on it.
Wed May 23, 2012 8:16 pm |
cb5331
Wed May 23, 2012 8:26 pm |
cb5331
Maybe your prop too. That could cause it.
Wed May 23, 2012 8:27 pm |
cj
i'am i missing something here. or are u in one of your moods  cb.
Wed May 23, 2012 8:32 pm |
cb5331
No problem other than a little clatter...set valves...PROBLEMS... Only one thing changed on this motor to make it start running like shit...I'd start with rechecking the only thing that changed... Think simple, stupid!
Wed May 23, 2012 8:38 pm |
